First post, by Vaylo
Hi,
so today i bought a new FDD so that i could finally throw away the old rusty (literally) drive that was with the 486 since like 1996. The old model is Mitsumi D359T3, new one is D359M3. As mentioned in the subject PC refuses to boot with the new drive and refuses to boot without any floppy drives connected. I understand the latter - that's a matter of setting up boot preferences in BIOS. But what's the deal with the new drive?
I noticed there are two difference between the two drives
- old one has all the pins on the IDE connector, new one is missing one pin but it's not like it's broken it has never been there
- old one has some jumpers that you can move around, new drive doesn't appear to have any jumpers
So what makes the old one so special (except for 30 year long bond with the rest of the machine) that the PC won't boot with out it?
BTW mobo is Zida 4DPS v2.1, AMD DX4-100.
Thanks for your advices in advance.
Reply 1 of 5, by konc
Just an idea, is the floppy drive cable that worked with the old drive twisted? If not try the new drive with one that is.
Reply 2 of 5, by Vaylo
Hi, thanks for suggestion. It is twisted.
Reply 3 of 5, by Horun
All new 1.44Mb drives are perma locked at ID1 so must go to end of a twisted cable of most motherboards (exception: some compaq and hp use a single straight connector cable) and BIOS needs first floppy as A drive.
Another option in some bios is "swap floppy", which makes the twisted end floppy "B" and the straight connector "A"....
we are assuming your old drive is set at ID1.....
Reply 4 of 5, by Vaylo
I tried all the combinations with connectors and bios settings but with no luck. There was one more discovery though...when the drive is accessed in DOS it makes an attempt to read the diskette but it ends up with an error saying the diskette is unreadable (i know there's no problem with the diskette as the other drive has no problem reading it). Wouldn't that suggest that the drive is actually faulty?
Reply 5 of 5, by Horun
Yes that does sound like the drive may be faulty.
