First post, by boby
Hi. I saw simillar threads about this problem but not what I had in mind. So caddy for above compaq model cost like a small fortune, so I was thinking does some kind of cable adapter exists that would work here, without caddy? Or could I find correct connector and try to build one?
If someone knows where to get this caddy cheep, that is even better.
Thank you.
