Problem with Pentium Pro build
Reply 20 of 24, by Sphere478
Reflow the card. Broken solder joint. Possibly on the ram or gpu
Sphere's PCB projects.
Reply 22 of 24, by Sphere478
boggsman wrote on 2024-02-06, 12:37:
I'm just gonna switch to a Quadro4 NVS 200. Should be a much better card.
Try a Quadro 2 with 7.76 drivers. Edit: needs a pci-agp adapter unless you can find a pci version
Try radeon 7500-9200-9250
Reply 23 of 24, by boggsman
Sphere478 wrote on 2024-02-06, 15:16:
What's wrong with the Quadro4? Reason I got it is because it's available and affordable. It's a DX7 card. Those cards are hard to find in PCI form. I want it to fit in the case, I don't think that will work with an adapter right?
Reply 24 of 24, by Sphere478
Aforementioned will prob be faster
