First post, by BitFlip
Hi guys,
Looking for some advice on memory configuration for this motherboard, ALL of my SDRAM sticks are only having half of their size detected e.g 256 -> 128 / 128 -> 64 etc, I'm looking to populate the motherboard for 512MB of RAM either in a 2 x 256 or 4 x 128, I have achieved this by using 4 x 256MB modules which should be 1GB and obviously this is wrecking my OCD. I will be honest and say memory configuration is not my strong point and I'm hoping someone with a bit more know how can push me in the right direction or maybe even link me to the correct modules that I need for this motherboard.
Motherboard link: https://theretroweb.com/motherboards/s/abit-ab-bx6-2.0
I have updated the BIOS to the last version available: QR, At the moment its got a Pentium 2 266 in the slot but I have a P3 500 on its way.
I have found these modules which I think may be compatible as the AB-BX6 does support EEC modules so I'm wondering if maybe these would work in a 2 x 256 configuration for 512MB of RAM?
https://www.kingston.com/dataSheets/KVR100X72RC2_256.pdf
Thanks again for all the help here on Vogons
Reply 1 of 8, by Unknown_K
Probably just a density issue. If Max RAM is 1GB and there are 4 DIMM slots you need low density 256MB 100Mhz SDRAM DIMMs to max it out (I forget if they need to be double sided).
Reply 3 of 8, by dionb
Unknown_K wrote on 2024-04-04, 08:11:
low density
"Low" or "high" density is a totally relative term and what is high density one day is low density the next. Please specify which density you mean by "low density" in this case.
i440BX will always be able to handle 64Mb chips (eg. 8Mx8) and usually can do 128Mb (eg 16Mx8) as well (the latter will be a BIOS limit). So a SIMM with 16 8Mx8 chips will reliably give you 128MB. In most cases 8 16Mx8 will give you 128MB too, and 16 16Mx8 will give you 256MB. 256Mb chips (32Mx8) will work at half capacity at best on a BX board.
Aside from density there can also be limits in the wiring. Some boards only accept two or three double-sided DIMMs, if more are installed the last two may only be single-sided. In that case higher density is actually the answer - if your 128MB DIMM with 16 8Mx8 chips is being detected as 64MB in DIMM3 or 4, replace it with a 128MB DIMM with 8 16Mx8 chips for the full 128MB.
Looking at this specific board, the manual uses pretty confused terminology, but given the following two statements:
maximum memory size is 1GB SDRAM [...] Those modules can be populated in any order […]
SDRAM
It's implied that 128Mb density is supported, and that all four DIMMs are fully wired.
So it appears that the DIMMs that are working at half capacity will have 256Mb chips.
OP, could you post the model numbers of the chips on your DIMMs?
Reply 4 of 8, by Trashbytes
dionb wrote on 2024-04-04, 09:25:
"Low" or "high" density is a totally relative term and what is high density one day is low density the next. Please specify whic […]
low density
SDRAM
In general Low density = 8 ICs on one side, High density = 16 ICs 8 on each side. BX will only handle low density single sided sticks and anything above 768Mb is pretty damn sketchy and not all BX chipsets will allow it, the BX6 2.0 even though it has 4 ram slots still only wants 768Mb in single sided low density sticks.
Reply 5 of 8, by dionb
Trashbytes wrote on 2024-04-04, 09:31:
No, that's single sided vs double sided. Density is a property of the chips, not of the number of the sticks.
Again, specify what you mean by "low density", i.e. give a number.
You cannot go over 512MB with single-sided DIMMs on a BX board as the max per single sided DIMM is 128MB (assuming 128Mb density). To reach 768MB on a BX board you need at least two double-sided 256MB DIMMs with 16 128Mb chips.
Reply 6 of 8, by Trashbytes
Seems you have had this little argument before so no need to rehash it, You can hit 768Mb with three 256Mb sticks even on a BX board as you suggest.
Looking that up its dual rank 16x8 256 MB sticks, 128MB per side 16 chips total. <--This is for BX steping 2, version 1 didn't support 16x8 and only supported 8x8 config, OP doesn't need to worry about version 1 with a BX6 2.0
Switched to using rank to try to clarify things better.
Reply 7 of 8, by hilram
I used to own this mainboard! I had it with a Celeron 300A overclocked to 450 MHz! Those were the days!
Advice : Stick to single sided memory sticks, and your mainboard will probably read the right capacity.
I think 4x 128 for a total of 512 MB is realistic for this board. I used to run it with 2 x 128.
Reply 8 of 8, by Trashbytes
hilram wrote on 2024-04-04, 12:44:
Its the perfect amount for 98 too
