First post, by Mamba
Hello, plain simple, I am trying to find the best media player for the best socket 7 cpu.
Media player classic black edition is a no go because it needs SSE.
Any alternative? Or a custom build of MPC-BE without the need of SSE?
Reply 1 of 18, by brian105
Foobar2000, VLC, Winamp?
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 3 of 18, by GemCookie
Try the Windows 98 build of MPlayer, or the "generic" build if running Windows XP. Older video cards might require 16-bit colour and/or the -vo directx command-line switch for optimal performance.
Asus Maximus Extreme (X38) | Core 2 Quad Q9550 | GTX 750 Ti | 8 GiB DDR3 | 120 GB SSD + 640 GB HDD | Sound Blaster X-Fi Titanium | WinXP64, 7, 11
Fujitsu D1215 board | P3 866 | Riva TNT2 M64 | 256 MiB PC133 CL2 | 120 GB HDD | WfW 3.11, Win95, NT, 2k, XP
Reply 5 of 18, by Babasha
Mamba wrote on 2024-04-08, 14:41:
VLC is not good for me.
Winamp is for mp3/audio AFAIK
Do not know foobar2000. Can it run mp4 enjoying some kind of hardware acceleration from gpu?
Nope - only hardware decoders (REAL Magic X card PCI or CrystalHD mini-pci) can help
Need help? Begin with photo and model of your hardware 😉
Reply 6 of 18, by Mamba
Babasha wrote on 2024-04-08, 16:10:
Let’s assume it can be done, my question is which program can do this without SSE?
That is what I am asking.
Reply 7 of 18, by progman.exe
libav and ffmpeg based stuff, maybe with compile flags off? Getting away from directshow might be the only way to get newer code, which stands to be faster.
I get surprisingly good performance from a core2duo running MPV from deb-multimedia, on Debian. 1080p h264 is nearly all fine, just the odd scene that slows down. But a SS7? I guess MPEG2 at DVD levels might be possible with good software, otherwise it'd have to be the pirate style of the time: 1/4 DVD size, as a DivX.
Otherwise, there is no insane graphics card that can help? Though the Radeon in the machine mentioned above has worse h264 decoding than in software.
Reply 8 of 18, by Babasha
Mamba wrote on 2024-04-08, 16:52:
X card tested with standart Windows Media Player (non-Classic) and Xmedia player.
Reply 10 of 18, by marxveix
Mamba wrote on 2024-04-10, 06:16:
Mplayer was a no go.
I think I will post on video subsection.
Mplayer works well, i have 3dnow version of it, maybe it needed dx9 or two files from dx9, I can share it later today or tomorrow.
31 different MiniGL/OpenGL Win9x files for all Rage 3 cards: Re: ATi RagePro OpenGL files
Reply 11 of 18, by Mamba
marxveix wrote on 2024-04-10, 06:55:
I have dx9.0c installed, tried the generic (486) version of Mplayer and crashed on startup.
Tried smplayer also, ti have a gui, same.
Reply 12 of 18, by marxveix
There are many players that work for AMD K6-II and K6-III for Dos/Win9x, for DVD i use ATiDVD 3.2 (Rage Pro/Rage128Pro). Mplayer should also support DVD, can someone help how to use mpf or mplayer without frontend for DVD, then i can uninstall ATiDVD. Added my old mplayer-k6.zip.
QuickView Pro
http://www.multimediaware.com/qv/
I have used mpf with this mplayer version (3dnow support).
https://www.upload.ee/files/16506586/mplayer-k6.zip.html
Reply 13 of 18, by Mamba
marxveix wrote on 2024-04-10, 08:39:
There are many players that work for AMD K6-II and K6-III for Dos/Win9x, for DVD i use ATiDVD 3.2 (Rage Pro/Rage128Pro). Mplayer […]
QuickView Pro
Thanks will try the mplayer k6, but can you please upload it on another site?
It is kind of virus filled…
Reply 14 of 18, by marxveix
Mamba wrote on 2024-04-10, 13:23:
QuickView Pro
For me its all fine (first time it shows banner, next time it downloads). Where you like it to be, i can upload it again if needed?
Second link + torrent:
https://archive.org/download/mplayer-k6/mplayer-k6.zip
https://archive.org/download/mplayer-k6/mplay … archive.torrent
Reply 15 of 18, by Mamba
marxveix wrote on 2024-04-10, 13:44:
For me its all fine (first time it shows banner, next time it downloads). Where you like it to be, i can upload it again if need […]
QuickView Pro
Seriously...?
Reply 16 of 18, by Horun
Yes was taken down. He left out the GNU GENERAL PUBLIC LICENSE text file so the bots figured it was not open source (which it is)
His post is MPC-HC v1.9.13.x86. You can get it from videohelp in the old versions...suggest you get the zip version.
Not sure how it will work with a K6-2 since it requires SSE2 iirc. added: the original dev page: https://mpc-hc.org/
Reply 17 of 18, by Sphere478
Foobar2000 is awesome! I still use it to this day.
Sphere's PCB projects.
Reply 18 of 18, by GemCookie
I went ahead and actually tested the two MPlayer builds. Indeed, the "generic" build crashes on a K6-2; however, the Windows 98 build seems to work. It will run on Windows 2000/XP as long as the included psapi.dll file is renamed.
