what will you do when your last hardware fails?
Reply 120 of 166, by chris2021
IBM bought Lotus? Or did they just pirate the name? Isn't that a blast from the past (no not Benny Cisco). Lotus 123, Symphony, etc. Anyone using that stuff at all? I'm sure a topic like that deserves its own thread.
Reply 121 of 166, by Plasma
Yes, in 1995.
Reply 122 of 166, by Shreddoc
When demand is there, things get ported to new forms. e.g. Roland MT-32 ---> MUNT. And subsequently mt32-pi.
Many who missed out on (acceptably priced) real versions, simply learn to love these new replacement and-in-some-ways-superior iterations. Thus achieving virtually the same results, and comparable satisfaction - job done.
Reply 123 of 166, by Sphere478
I’m having trouble accepting that anything about a ceramic pentium/486 has a shelf life measurable on a human time span, maybe a geological timespan or even a cosmic one,
I literally plugged a pentium in the other day that had been outside in the rain and sun for probably 20 years and it worked fine 🤣
Sphere's PCB projects.
Reply 124 of 166, by charliegolf
Luckily I'm significantly older than a lot of my retro hardware, so I will die first😁.
Then I want to be pushed out to sea in a viking longboat with all my gear and set on fire with a flaming arrow!
YouTube:
66Mhz Brain
Reply 125 of 166, by Shreddoc
charliegolf wrote on 2022-02-21, 18:18:
No need for flaming arrow, just have some early Athlons set up on the longboat, set to all run simultaneously ...with no heatsink.
Reply 126 of 166, by FioGermi
It genuinely surprises me how some of these components are even still alive in 2022. Especially some of the later stuff like 3DFX cards when most 90s computer cases had bad or non existent airflow to keep things cool. You had OEMs building Pentium machines with dinky passive heatsinks. Maybe only the PSU fan to exhaust all the heat. Its just torturous to a modern temperature freak 😁
I don't know if that is a result of better quality standards, or just pure luck. There are tons of Voodoo's from 97 alive and kicking. Yet we already are starting to see some 10 series GPUs go up in smoke 😜
Reply 127 of 166, by chris2021
Do you mean entire mobos or just the cpu's? An entire motherboard lasting an extended period of time would be a marvel. Just the cpu, not so much. The cpu is the last component to fail under "norrmal" circumstances. Perhaps the plethora of cpus that still work were pulled from mobos that died. The various mobo components aren't built to the same standards, don't have the same degree of longevity built into them. If they were, there were likely be as high an occurrence of dead cpus. The engine in my Grandn Prix might last to 300k miles. The radio died aroumd half that mileage. There are loads more working 3800s then there are accomanying radios it seems. Granted thenengine receives consistent maintenance, eh most of the time. But the 3800 is one of the most resilient engines on the road, far and away, because of the way it was designed.
It may seem like a painfully obvious point. But just consider that the lower quality mobo components act as a fuse for the cpu. When things get too real, the cheaper componentz give up the ghost. And the cpu lives on.
Look at all the dead core series chips on ebay. They're not impervious.
Reply 128 of 166, by Plasma
A motherboard simply has more potential points of failure than a CPU. I don't think it's necessarily lower standards or quality. Besides bad capacitors and leaking batteries they usually last a long time. I have XT motherboards with all original components that still work fine.
Reply 129 of 166, by BitWrangler
Say you've got a CPU that's got a 99% chance of working after 10 years... great. Say you've got a motherboard that has 100 components that each have a 99% chance of working after 10 years... grr-not-so-fast... that's 0.99 to the power of a hundred, so 36.6% chance of the motherboard working in 10 years....
Well hopefully 1% failure in 10 years is actually a pretty high chance of failure and it's better at 0.1 ... but that still gives you a 90% chance of still alive for 100 parts in lose formation vs 99.9 of a single one.
Reply 130 of 166, by chris2021
Plasma wrote on 2022-02-22, 01:10:
And for your 1 working xt motherboard I've seen a few dozen that don't work. And yes corrosion and bad passive components have a lot to do with failures over long periods of time. But I'd bet anything in the cases wher1 a chip goes bad, 10 to 1 at least it's a peripheral ic, not the micro. I personally have never seen a failed cpu. You usually have to really torture them for failure.to occur.
Reply 131 of 166, by BitWrangler
I might have killed a Cyrix PR166 (133 stock actual) that I ran at 83x2 for 5 years at 3.5V but while I've had CPUs turn up flaky from collected junk, I've never known what happened to them before that.
Reply 132 of 166, by Plasma
chris2021 wrote on 2022-02-22, 01:53:
How many ICs are on a motherboard? Probably at least 10x more than the number of CPUs. It's statistics.
I have had a Celeron 333 and an Athlon 2800 fail. Neither was abused. The Celeron ran 24/7 for over a decade. I popped in a new one and the system kept going until it was retired.
I have also had several motherboards fail. In all cases but one I was able to repair them. When motherboards "don't work" the problem is usually a single component that can be replaced.
Reply 133 of 166, by FioGermi
I don't think iv run into a dead CPU yet. I've killed CPUs with my own stupidity before, but never one that just decided to quit on its own 😜
A CPU is usually the last point of failure i worry about. They seem pretty tough. Motherboards/RAM on the other hand....
Reply 134 of 166, by chris2021
And the amount of transistors on a cpu is probably multiples of every other chip. By all rights it should be more prone to failure then any other chip.
Reply 135 of 166, by Plasma
It depends on the configuration but RAM is usually the most. 1 GB of RAM is more than 2x the transistors in a Core i7.
Reply 136 of 166, by chris2021
Yes ram could exceed the tranny count. And ram is multiple times more likely to fail then the cpu.
Reply 137 of 166, by charliegolf
Shreddoc wrote on 2022-02-21, 21:50:
Good point!
YouTube:
66Mhz Brain
Reply 138 of 166, by chris2021
I bet the mobo burns up quicker 😀
Reply 139 of 166, by Plasma
chris2021 wrote on 2022-02-22, 07:37:
That's my point. The RAM isn't necessarily lower quality than the CPU.
