First post, by lafoxxx
Hi.
I always used old pbrush/mspaint (win95-XP version). I even it copied to system32 and called it "mspnt.exe" so I could quick-launch it using "Run...".
New mspaint from Win7 onwards is glitchy/poorly written (bad hotspot pixel location in cursors, flickering text box which is not really transparent but takes a screenshot of whatever's underneath it, complains about "at least 1x1 size" when you shrink the image, etc. ), lacks useful features (invert colors) though there are some useful features like Ctrl+Mousewheel to Zoom.
Are there any (newer) apps which can replace the old mspaint, and not be as bad as the new one?
Main requirements:
Lightweight (ideally -- single .exe), few kb
No fancy stuff (like these "smear" brushes in Win7+ mspaint). Think ZSoft Paintbrush/Deluxe Paint tool set (pixelated).
Ctrl+Mousewheel to Zoom support
Ideally old mspaint with Ctrl+Mousewheel would be great, though I'm not sure if it exists.
I do have Photoshop, but it's too complex for required tasks, takes a while to open. GIMP is worse.
Reply 1 of 12, by konc
You could try paint.NET (https://www.getpaint.net/).
It's not as simple as the old ms paint, but it's not photoshop either.
Reply 3 of 12, by MrFlibble
A few years ago I was also looking for a good MSPaint alternative, but found nothing that would be as close to it as I'd like. mtPaint, mentioned above, is a nice tool for working with indexed images, but it has a lot of non-standard controls which I never got used to, and on the whole I would not imagine it as functionally similar to MSPaint.
During my relatively brief Linux period I discovered an almost perfect Paint clone called KolourPaint, which I believe is a nearly exact replica of the original MSPaint (at least, the way I remember it from Win98SE), with a few QoL improvements added like the aforementioned Ctrl+Mouse wheel zoom and some other features, if memory serves. Apparently, there is a Windows port, as suggested by Wikipedia, available through KDE on Windows, but I haven't tried it.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 4 of 12, by Jo22
Hm. Maybe check the beta versions of Windows? Maybe from the early Longhorn days?
Could be that some of the betas had new functions but the old look of MS Paint, not sure.
MS Paint was very popular among pixel-artists, who created sprites for indie games etc.
Reply 6 of 12, by Jo22
GIMP truely is a mighty tool, even though I like my copy of CS2 on Mac! 😁
It's just that MS Paint was the defacto standard* for pixel artists.
A whole community/society is based around MS Paint!
As someone who preferred the old Paintbrush from Windows 3.x (based on ZSoft Paintbrush, ≠MS Paint),
I too had a hard time understanding why..
I always missed the grid and the arrow key control..
Anyway, MS Paint shines through its simplicity. Everything's quick to access, no menus, no hidden settings etc.
It reminds me of that iconic Icon Editor from Borland Turbo Pascal for Windows.
Hm. Or was it from Central Point PC-Tools 7.x? 🤔
Anyway, MS Paint is like a digital version of the paper tools that were used at making Super Mario Bros. for the Famicom.
It's very straight down to the matter, no eye candy.
https://www.youtube.com/watch?v=DLoRd6_a1CI
(*From this millennium, at least. We all heard the tales of the olden days of DPaint).
Reply 7 of 12, by lafoxxx
Thanks everyone!
Vista version of Mspaint looks best so far. While lacking Ctrl+Mousewheel to Zoom, you can use LMB/RMB to zoom in/out when Zoom tool is selected. Not perfect, but at least more usable.
Reply 8 of 12, by Azarien
cyclone3d wrote on 2022-05-27, 02:19:
Gimp is great.
GIMP is very unintuitive even for very simple stuff.
Like… how to draw a circle? If you need to google that, it's not a program that's easy to use.
Paint.net is a good alternative for MS Paint, one thing I wish it had was rotation by an arbitrary angle.
Reply 9 of 12, by Oetker
Azarien wrote on 2022-05-28, 21:50:
It does, you can rotate a selected area.
Reply 11 of 12, by dr_st
Apparently, you select an area, grab the anchor at the top, and rotate.
Reply 12 of 12, by konc
Azarien wrote on 2022-05-29, 10:17:
How do I rotate by e.g. 7 degrees?
There is a whole panel for this and operates at layer level, "Rotate/Zoom" under Layers menu.
https://www.getpaint.net/doc/latest/RotateZoo … ft%20%2B%20Z%20.
But I understand why you might have missed it, this panel is relatively new. In older versions you had to do it using the "Layers" window at the bottom right and it wasn't obvious.
