What modern activity did you get up to today?
Reply 1000 of 1038, by lti
Windows is nagging me to use the ad-supported New Outlook. I'm going to try whatever Linux distro is on one of the flash drives on my desk (probably Lubuntu 22.04 since that's the last one I installed on physical hardware). I'll have to check what's on that Sandisk Ultra Flair that gets too hot to touch. I need to clean the USB ports on my computer first because only a few ports work at USB 3.x speed instead of USB 2.0 (and one port on the USB hub in my monitor doesn't work at all).
Also, my oven door broke off again. I replaced it one year ago (I found the order confirmation email - genuine replacement parts, not Amazon "upgrades"), but it's made out of plastic that's more brittle than a '90s laptop. I'm going to treat it the same way I treat those old laptops - ABS pipe cement. I guess appliance repair is a retro activity, though. Today, even people who aren't affiliated with the manufacturers will tell you to just buy a new one without considering where the money needs to come from. When you mention the cost, reduced quality, and the occasional forced arbitration agreement that you're forced to accept before you can even open the box (see LG refrigerators with their extremely unreliable compressors and the fact that the person who delivered the appliance is the one opening the box, not you), you're told to just get over it and keep buying. Modern life sucks.
Reply 1001 of 1038, by TheChexWarrior
My new Fujicom curved screen. And Wise thin-pc with Windows 98 SE. Those combination are wonderful to my fillings!!!!
Reply 1002 of 1038, by twiz11
BitWrangler wrote on 2024-03-17, 23:24:
I take it "frozen tundra" is nowhere near Buffalo, guy on Craigslist has a bunch of cases $5 a pop.
I have seen ppl string up their boards on the wall though, like a dissected insect 🤣 nails/screws and zipties.
well im from the area and i got an empty case id let you have for the cost of shipping
RETIRED
This user is no longer active on VOGONS.
Reply 1003 of 1038, by StriderTR
Built my new family "server" and installed Ubuntu 22.04. Worked on getting it configured.
Ryzen 2600. 16GB RAM. 512GB NVMe. Had most of the hardware on-hand already, not being used. Just needed a motherboard and that arrived Sunday.
Once it's all done, it will be somewhat "headless", controlled by remote desktop. Used for running small family game servers (5-10 players). Heavily modded Minecraft most of the time, and Ark Survival Evolved every so often.
This setup may be overkill for those uses, but better to have extra, and room to expand, than not enough. 😀
Old servers were an FX-8350 x 8GB and an old Phenom II x 8GB. This one replaces both, is more powerful, and more efficient. Win win in my book.
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
Reply 1004 of 1038, by Bruninho
Steam had a bargain on entire Tomb Raider Survivor trilogy so I went for it...
JOBS, Steve.
Reply 1005 of 1038, by Nexxen
Updated 3 machines: (all SSDs)
1) my main rig, Linux went well; 2ndary Linux was 3 months old and updated under 10 minutes;
Win10 took 2 hours and I got an error on 2024-01 update for lack of space on recovery partition (if that is the error) and then I left it for another day
2) Linux on a laptop; under 10 minutes for an 8 month period update.
3) laptop; Linux, 1.5 year updates: cool, 15 minutes; Win10 took forever, more than 4 hours, for a 1.5 year update; got same error as above
Why Win10 takes forever even on NVMEs?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 1006 of 1038, by StriderTR
Nexxen wrote on 2024-04-05, 00:57:
I see I'm not the only one that can't stand the fact Windows is so insanely slow when updating. In all reality, if it wasn't for my software and DirectX needs, I would run Ubuntu on everything. As it is now, I only run Windows on my primary system, everything else is Linux.
As far as my modern activities...more printing. 😀
Have decided to invest in a 2nd printer, an Ender 3 V3 SE my wife can use to print and sell all the designs she's making for her Etsy page. It's faster than my "upgraded" original Ender 3 (Glass bed, dual-z axis drives, direct drive extruder, CR Touch, etc.). It can do about 80mms now, but the V3 SE can do closer to 250mms and only runs a little over $200. Seems like a good deal to me.
I'm thinking of doing something similar, but just for "retro PC" related things, and only as time permits since I work full time.
    139.45 KiB
    143.87 KiB
    128.2 KiB
    280.67 KiB
Reply 1007 of 1038, by AmiSapphire
Messing with an old Seagate Momentus 7200.3 320GB hard drive with bad sectors... out of boredom. This WAS my original FTP Archives drive but I long moved the data off to a Hitachi 500GB hard drive, and that is now the FTP Archives drive. This data is also on my main NAS.
Speaking of the NAS, another 4TB hard drive will be added to the setup (ordered the drive and should arrive soon), though I will need to change the motherboard in order to do so.
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 1008 of 1038, by lti
With my Internet connection, downloading the updates is what takes the most time, and it still takes much more time than updating Linux. I noticed that the progress indicator on cumulative updates goes to 100% when it's really about 50% complete, and the download speed starts throttling after some time period.
Reply 1009 of 1038, by Nexxen
lti wrote on 2024-04-07, 16:28:
So, the problem is on their end?
I have 2.5Gb fiber optics internet, and works @max speed most of the time (2.3 usually).
Reply 1011 of 1038, by AmiSapphire
The hard drive has arrived! Initial stats are good; will have to run some tests on it sometime later.
879.35 KiB
Toshiba MG03ACA400 4TB enterprise SATA hard drive.
smartctl stats
ami-sapphire@FinalRun-Linux:~$ sudo smartctl -x /dev/sdb
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.5.0-26-generic] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 3.5" MG03ACAxxx(Y) Enterprise HDD
Device Model: TOSHIBA MG03ACA400
Serial Number: 5777KLXIF
LU WWN Device Id: 5 000039 7cba00dd7
Firmware Version: FL1A
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5319
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Apr 8 13:44:53 2024 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 619) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
Show last 335 lines
                                        SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 050 - 0
2 Throughput_Performance P-S--- 100 100 050 - 0
3 Spin_Up_Time POS--K 100 100 001 - 11761
4 Start_Stop_Count -O--CK 100 100 000 - 38
5 Reallocated_Sector_Ct PO--CK 100 100 050 - 0
7 Seek_Error_Rate PO-R-- 100 100 050 - 0
8 Seek_Time_Performance P-S--- 100 100 050 - 0
9 Power_On_Hours -O--CK 015 015 000 - 34051
10 Spin_Retry_Count PO--CK 100 100 030 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 38
191 G-Sense_Error_Rate -O--CK 100 100 000 - 1
192 Power-Off_Retract_Count -O--CK 100 100 000 - 31
193 Load_Cycle_Count -O--CK 100 100 000 - 4532
194 Temperature_Celsius -O---K 100 100 000 - 23 (Min/Max 17/51)
196 Reallocated_Event_Count -O--CK 100 100 000 - 0
197 Current_Pending_Sector -O--CK 100 100 000 - 0
198 Offline_Uncorrectable ----CK 100 100 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 253 000 - 0
220 Disk_Shift -O---- 100 100 000 - 0
222 Loaded_Hours -O--CK 023 023 000 - 30987
223 Load_Retry_Count -O--CK 100 100 000 - 0
224 Load_Friction -O---K 100 100 000 - 0
226 Load-in_Time -OS--K 100 100 000 - 503
240 Head_Flying_Hours P----- 100 100 001 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 51 Comprehensive SMART error log
0x03 GPL R/O 64 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (64 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 34051 -
# 2 Short offline Completed without error 00% 34051 -
# 3 Short offline Completed without error 00% 33897 -
# 4 Short offline Completed without error 00% 33729 -
# 5 Short offline Completed without error 00% 33561 -
# 6 Short offline Completed without error 00% 33393 -
# 7 Short offline Completed without error 00% 33225 -
# 8 Short offline Completed without error 00% 33057 -
# 9 Short offline Completed without error 00% 32889 -
#10 Short offline Completed without error 00% 32721 -
#11 Short offline Completed without error 00% 32554 -
#12 Short offline Completed without error 00% 32386 -
#13 Short offline Completed without error 00% 32218 -
#14 Short offline Completed without error 00% 32088 -
#15 Short offline Completed without error 00% 31920 -
#16 Short offline Completed without error 00% 31752 -
#17 Short offline Completed without error 00% 31584 -
#18 Extended offline Completed without error 00% 31549 -
#19 Short offline Completed without error 00% 31434 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 2
SCT Version (vendor specific): 1 (0x0001)
Device State: Active (0)
Current Temperature: 22 Celsius
Power Cycle Min/Max Temperature: 22/23 Celsius
Lifetime Min/Max Temperature: 17/51 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 5/55 Celsius
Min/Max Temperature Limit: 5/55 Celsius
Temperature History Size (Index): 478 (80)
Index Estimated Time Temperature Celsius
81 2024-04-08 05:47 26 *******
... ..( 2 skipped). .. *******
84 2024-04-08 05:50 26 *******
85 2024-04-08 05:51 25 ******
86 2024-04-08 05:52 25 ******
87 2024-04-08 05:53 25 ******
88 2024-04-08 05:54 26 *******
89 2024-04-08 05:55 25 ******
90 2024-04-08 05:56 25 ******
91 2024-04-08 05:57 25 ******
92 2024-04-08 05:58 26 *******
93 2024-04-08 05:59 26 *******
94 2024-04-08 06:00 25 ******
95 2024-04-08 06:01 26 *******
96 2024-04-08 06:02 25 ******
... ..( 27 skipped). .. ******
124 2024-04-08 06:30 25 ******
125 2024-04-08 06:31 26 *******
126 2024-04-08 06:32 25 ******
127 2024-04-08 06:33 26 *******
... ..( 7 skipped). .. *******
135 2024-04-08 06:41 26 *******
136 2024-04-08 06:42 27 ********
137 2024-04-08 06:43 26 *******
... ..( 3 skipped). .. *******
141 2024-04-08 06:47 26 *******
142 2024-04-08 06:48 25 ******
143 2024-04-08 06:49 25 ******
144 2024-04-08 06:50 26 *******
145 2024-04-08 06:51 25 ******
146 2024-04-08 06:52 26 *******
147 2024-04-08 06:53 25 ******
148 2024-04-08 06:54 26 *******
149 2024-04-08 06:55 25 ******
150 2024-04-08 06:56 25 ******
151 2024-04-08 06:57 26 *******
152 2024-04-08 06:58 25 ******
... ..( 32 skipped). .. ******
185 2024-04-08 07:31 25 ******
186 2024-04-08 07:32 26 *******
187 2024-04-08 07:33 25 ******
188 2024-04-08 07:34 25 ******
189 2024-04-08 07:35 26 *******
... ..( 11 skipped). .. *******
201 2024-04-08 07:47 26 *******
202 2024-04-08 07:48 25 ******
203 2024-04-08 07:49 25 ******
204 2024-04-08 07:50 26 *******
205 2024-04-08 07:51 25 ******
... ..( 38 skipped). .. ******
244 2024-04-08 08:30 25 ******
245 2024-04-08 08:31 26 *******
246 2024-04-08 08:32 25 ******
247 2024-04-08 08:33 25 ******
248 2024-04-08 08:34 25 ******
249 2024-04-08 08:35 26 *******
... ..( 10 skipped). .. *******
260 2024-04-08 08:46 26 *******
261 2024-04-08 08:47 25 ******
262 2024-04-08 08:48 26 *******
263 2024-04-08 08:49 26 *******
264 2024-04-08 08:50 25 ******
265 2024-04-08 08:51 25 ******
266 2024-04-08 08:52 26 *******
267 2024-04-08 08:53 25 ******
268 2024-04-08 08:54 26 *******
269 2024-04-08 08:55 25 ******
... ..( 34 skipped). .. ******
304 2024-04-08 09:30 25 ******
305 2024-04-08 09:31 26 *******
306 2024-04-08 09:32 25 ******
307 2024-04-08 09:33 25 ******
308 2024-04-08 09:34 25 ******
309 2024-04-08 09:35 26 *******
321 2024-04-08 09:47 26 *******
322 2024-04-08 09:48 25 ******
323 2024-04-08 09:49 26 *******
324 2024-04-08 09:50 25 ******
325 2024-04-08 09:51 26 *******
326 2024-04-08 09:52 25 ******
327 2024-04-08 09:53 25 ******
328 2024-04-08 09:54 25 ******
329 2024-04-08 09:55 26 *******
330 2024-04-08 09:56 25 ******
... ..( 33 skipped). .. ******
364 2024-04-08 10:30 25 ******
365 2024-04-08 10:31 26 *******
366 2024-04-08 10:32 26 *******
367 2024-04-08 10:33 25 ******
368 2024-04-08 10:34 25 ******
369 2024-04-08 10:35 26 *******
... ..( 4 skipped). .. *******
374 2024-04-08 10:40 26 *******
375 2024-04-08 10:41 27 ********
376 2024-04-08 10:42 26 *******
377 2024-04-08 10:43 27 ********
378 2024-04-08 10:44 26 *******
382 2024-04-08 10:48 26 *******
383 2024-04-08 10:49 25 ******
384 2024-04-08 10:50 26 *******
385 2024-04-08 10:51 26 *******
386 2024-04-08 10:52 25 ******
387 2024-04-08 10:53 26 *******
388 2024-04-08 10:54 25 ******
392 2024-04-08 10:58 25 ******
393 2024-04-08 10:59 26 *******
394 2024-04-08 11:00 25 ******
... ..( 29 skipped). .. ******
424 2024-04-08 11:30 25 ******
425 2024-04-08 11:31 26 *******
426 2024-04-08 11:32 25 ******
427 2024-04-08 11:33 26 *******
430 2024-04-08 11:36 26 *******
431 2024-04-08 11:37 25 ******
432 2024-04-08 11:38 26 *******
433 2024-04-08 11:39 26 *******
434 2024-04-08 11:40 26 *******
435 2024-04-08 11:41 27 ********
... ..( 2 skipped). .. ********
438 2024-04-08 11:44 27 ********
439 2024-04-08 11:45 26 *******
442 2024-04-08 11:48 26 *******
443 2024-04-08 11:49 25 ******
444 2024-04-08 11:50 26 *******
445 2024-04-08 11:51 25 ******
446 2024-04-08 11:52 25 ******
447 2024-04-08 11:53 26 *******
448 2024-04-08 11:54 26 *******
449 2024-04-08 11:55 26 *******
450 2024-04-08 11:56 25 ******
451 2024-04-08 11:57 25 ******
452 2024-04-08 11:58 26 *******
453 2024-04-08 11:59 25 ******
454 2024-04-08 12:00 26 *******
457 2024-04-08 12:03 26 *******
458 2024-04-08 12:04 25 ******
... ..( 26 skipped). .. ******
7 2024-04-08 12:31 25 ******
8 2024-04-08 12:32 26 *******
9 2024-04-08 12:33 25 ******
10 2024-04-08 12:34 25 ******
11 2024-04-08 12:35 26 *******
... ..( 14 skipped). .. *******
26 2024-04-08 12:50 26 *******
27 2024-04-08 12:51 25 ******
30 2024-04-08 12:54 25 ******
31 2024-04-08 12:55 26 *******
32 2024-04-08 12:56 25 ******
33 2024-04-08 12:57 26 *******
34 2024-04-08 12:58 26 *******
35 2024-04-08 12:59 25 ******
36 2024-04-08 13:00 26 *******
37 2024-04-08 13:01 25 ******
... ..( 31 skipped). .. ******
69 2024-04-08 13:33 25 ******
70 2024-04-08 13:34 26 *******
73 2024-04-08 13:37 26 *******
74 2024-04-08 13:38 27 ********
... ..( 3 skipped). .. ********
78 2024-04-08 13:42 27 ********
79 2024-04-08 13:43 26 *******
80 2024-04-08 13:44 ? -
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 38 --- Lifetime Power-On Resets
0x01 0x010 4 34051 --- Power-on Hours
0x01 0x018 6 441414957843 --- Logical Sectors Written
0x01 0x020 6 639164751 --- Number of Write Commands
0x01 0x028 6 744410986518 --- Logical Sectors Read
0x01 0x030 6 1428024883 --- Number of Read Commands
0x02 ===== = = === == Free-Fall Statistics (rev 1) ==
0x02 0x010 4 1 --- Overlimit Shock Events
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 34051 --- Spindle Motor Power-on Hours
0x03 0x010 4 30987 --- Head Flying Hours
0x03 0x018 4 4532 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 23 --- Current Temperature
0x05 0x010 1 25 N-- Average Short Term Temperature
0x05 0x018 1 26 N-- Average Long Term Temperature
0x05 0x020 1 51 --- Highest Temperature
0x05 0x028 1 17 --- Lowest Temperature
0x05 0x030 1 49 N-- Highest Average Short Term Temperature
0x05 0x038 1 25 N-- Lowest Average Short Term Temperature
0x05 0x040 1 32 N-- Highest Average Long Term Temperature
0x05 0x048 1 26 N-- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 55 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 5 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 1242 --- Number of Hardware Resets
0x06 0x018 4 0 --- Number of Interface CRC Errors
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 56 N-- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 4 0 Command failed due to ICRC error
0x0008 4 0 Device-to-host non-data FIS retries
0x000a 4 0 Device-to-host register FISes sent due to a COMRESET
0x000b 4 0 CRC errors within host-to-device FIS
0x000d 4 0 Non-CRC errors within host-to-device FIS
Reply 1012 of 1038, by StriderTR
Took a break from working on my new Ryzen 2600/Ubuntu powered "family game server" and enjoyed the effects from the 86% of the "Great North American Eclipse" I could see here in Wisconsin. 😜
The coolest part was seeing all the shadows turn into crescent shapes. Just wish I would have had the time to drive about 8 hours south to be in the path of totality, but, I've done that before, so missing this one wasn't so bad.
Reply 1013 of 1038, by BitWrangler
I was under path of totality, but just got to see a crescent for a couple of seconds 5 mins before and after and a half second glimpse of corona through the clouds.
Reply 1014 of 1038, by StriderTR
BitWrangler wrote on 2024-04-08, 20:55:
Even with only 14% of the suns disk visible, it was still far too bright to see with anything other than proper solar viewing gear, that I don't have. So, I settled for the cool "dimming" effect, the wind picked up, and we seen those crescent shadows for several minutes up to and after max coverage. Was still an enjoyable experience.
Now, back to working on my server. 😀
Reply 1015 of 1038, by lti
I woke up to my desktop wallpaper being replaced with a badly-scaled (blurry) and badly-cropped (the bottom was cut off under the taskbar) message about Windows 10's end of support (in a year and a half). It really didn't look like anything Microsoft themselves would do, but it had functioning buttons and Malwarebytes found nothing.
Why does all software now use language like "not now" or "maybe later" for a button that would have been labeled "No" in the past?
Now I need to look for a Linux replacement for the video software I've been running. I still use VirtualDub in combination with AviSynth for some video editing tasks. I thought of building a dedicated Windows 7 system, but I would need a CPU with good single-thread performance to run QTGMC (or find a better deinterlacing algorithm that is multi-threaded).
Reply 1016 of 1038, by StriderTR
lti wrote on 2024-04-17, 14:55:
No idea about the wallpaper change, that's not something I'm used to seeing on anything but managed machines, like those you use at work.
I also dislike the wording used on a lot of new software. It's all geared to persistently bug you, and I get some people need such reminders, but I for one don't. I often look for ways to disable any and all notifications from applications, and customize the ones I see in my OS. I've removed many apps that won't let me stop them from being intrusive. 😜
On a side note, I will likely still use Windows 10 after it's EOL. It's not like it stops working, it simply stops getting updates. I'm not worried much about security in the short-term because of how I have things setup. Still, I guess it will come down to how I feel when the time comes. I'm definitely not in any hurry to switch to 11. I didn't even move to 10 from 7 until it became necessary for software and games that I use.
As far as my modern activity for today. After years of lurking on Reddit, I finally created an account. 😀
Reply 1017 of 1038, by konc
Wow I can't believe that MS really changed your background to tell you, in a sloppy way, that win10 will be simply unsupported a year later. I really can't, I'd do some more checks and googling to verify that this is legit.
Reply 1018 of 1038, by acl
TheChexWarrior wrote on 2024-03-21, 14:49:
47.03 KiB
Your light switch is incredible !
Reply 1019 of 1038, by ubiq
Had my HTPC/couch gaming PC on the bench today. The video was cutting out within seconds of booting up, and I was really hoping it wasn't my 2080 Super dying. Was hoping it was maybe a PSU issue. As it turned out, simply uninstalling the EVGA OC util I was using to manage the GPU fans seemed to fix it right up.
1.17 MiB
Here's hoping it'll be good to go. I have no desire to plunk down for a new GPU any time soon. 😬😬😬
