Reply 1000 of 1038, by lti
Windows is nagging me to use the ad-supported New Outlook. I'm going to try whatever Linux distro is on one of the flash drives on my desk (probably Lubuntu 22.04 since that's the last one I installed on physical hardware). I'll have to check what's on that Sandisk Ultra Flair that gets too hot to touch. I need to clean the USB ports on my computer first because only a few ports work at USB 3.x speed instead of USB 2.0 (and one port on the USB hub in my monitor doesn't work at all).
Also, my oven door broke off again. I replaced it one year ago (I found the order confirmation email - genuine replacement parts, not Amazon "upgrades"), but it's made out of plastic that's more brittle than a '90s laptop. I'm going to treat it the same way I treat those old laptops - ABS pipe cement. I guess appliance repair is a retro activity, though. Today, even people who aren't affiliated with the manufacturers will tell you to just buy a new one without considering where the money needs to come from. When you mention the cost, reduced quality, and the occasional forced arbitration agreement that you're forced to accept before you can even open the box (see LG refrigerators with their extremely unreliable compressors and the fact that the person who delivered the appliance is the one opening the box, not you), you're told to just get over it and keep buying. Modern life sucks.
