kixs wrote on 2024-06-03, 12:04:It was bound to happen... a few weeks ago I got a newer ride. 2018 Opel Astra K Sports Tourer 1.6CDTI. I hope it will be as low […]
It was bound to happen... a few weeks ago I got a newer ride. 2018 Opel Astra K Sports Tourer 1.6CDTI. I hope it will be as low maintenance like the previous one 😁
It is sounding like there is a lot of stuff to keep on top of with that engine..
https://en.wikipedia.org/wiki/GM_Medium_Diesel_engine
I am reading up on it due to North American applications... (Terrain/Equinox/Cruze) the Astra applications sound like a pain in the ass to get to, as I would assume is the Cruze.... I might have to take a deep dive into the SUV installation though to see if there's a shadetree mechanic judo-fu trick possible for the chain, i.e. the kind of way you can do some gas engine water pumps in under 2 hours when it's a 10 hour book time.
more about it here too https://www.motortrend.com/news/tech-deep-div … h7-turbodiesel/
Now I was reading elsewhere, think a diesel Terrain review, that a limiting factor on it in that platform is overheating at high load, not sure if it's only that application, or whether it is common to all. Shouldn't happen in "normal" use, but who the heck wants to be normal 🤣
Yeah, the angle I am approaching this from is that I'm trying to figure out how to get a 30MPG (US gallon) plus "tow pig" that can move 3000lb minimum. The chassis/platform does it in the case of the Terrinox but the engine doesn't. ... So naturally a gearhead's thoughts turn to methanol injection or something... it's kinda the diametric opposite to nitrous if that's what you're thinking, makes less heat rather than more.
edit: not even sure I'd have to DO anything about the heat issue, may be that it's only a cover their ass thing because someone bound to try going over the Rockies with overloaded "3500lb" trailer on a day when it's 120F or so... i.e. sustained climb, high load, high altitude, high heat fustercluck.... pretty much anything built before 2010 would fail at it's max tow rating in those conditions.
