Can't execute batch file
First post, by tronds
I'll go straight to the problem.
When I try to execute this batch file, Dosbox freezes (No error message) and the only thing to do is to use Task Manager and force-quit it.
This is the bat file I'm trying to execute:
ECHO OFF
CLS
:MENU
ECHO.
ECHO ...............................................
ECHO PRESS 1 or 2 to select your task, or 3 to EXIT.
ECHO.
ECHO 1 - Export Favorites from COMPUTER to PERSONAL DRIVE (P:)
ECHO 2 - Import Favorites from PERSONAL DRIVE (P:) to COMPUTER
ECHO 3 - EXIT
ECHO.
SET /P M=Type 1, 2, or 3, then press ENTER:
IF %M%==1 GOTO EXPORT
IF %M%==2 GOTO IMPORT
IF %M%==3 GOTO EOF
:EXPORT
XCOPY "%userprofile%"\Favorites\*.* P:\Favorites\ /S/Y
GOTO MENU
:IMPORT
XCOPY P:\Favorites "%userprofile%"\Favorites\*.* /S
GOTO MENU
Whenever I try to launch another bat-file it works fine, so I guess it's a problem with this specific bat-file. Could someone confirm this?
Thank you in advance.
Reply 1 of 6, by HunterZ
I don't have access to DOSBox at the moment, but at which point does it freeze?
Reply 3 of 6, by collector
Your batch file is using XCOPY and you are trying to run it in DOSBox? As DosFreak said, why are you trying to run this in DOSBox?
Reply 4 of 6, by leileilol
Most importantly, why are you trying to use DOSBox to copy your Internet Explorer favorites links to a USB stick?
FUCK "AI"
Reply 6 of 6, by rfnagel
Also, DOSBox doesn't support LFNs, or XCOPY, or "%userprofile%", etc... 😉
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
