First post, by Nic-93
How can i make the game run on it?, i had treid at a friend trying to get the game working on it, but dosbox just quits, i had set virtual hard drive up and ready.
Follow the 60 seconds guide and use dosbox directly. Make sure you use the original mefia it came on.
Next time post in the dosbox section of the forum.
i werent sure where to post it ^^;
could you move the post to that section?.
wrote:Follow the 60 seconds guide and use dosbox directly. Make sure you use the original mefia it came on.
this post can be closed so the other can be on the dosbox forum section, sorry ^^;
He, when I say next time, I mean when you got another problem 😉
wrote:He, when I say next time, I mean when you got another problem 😉
Oh, alright ^^
I posted this over in your other thread:
You might be having the same problem as I did... check this message thread -> Re: Transport Tycoon Deluxe "Fatal Error TNT.10049: Ran out of stack buffers" [FIXED]
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
