First post, by sliderider
- l33t++
I am not talking about the ones that go on the end of a power supply cable, I mean the ones that solder onto the video card. I can find the cable end ones, but not the ones that solder onto the card.
You can get 'em from Mouser.
wrote:You can get 'em from Mouser.
That part does not look a thing like a 6-pin PCIe connector. It's got 24 pins.
It is the correct part. Amphenol PE series, right angle PCB mount, 4.2MM pitch, 6 position double row. They use a generic picture for the entire product series.
wrote:It is the correct part. Amphenol PE series, right angle PCB mount, 4.2MM pitch, 6 position double row. They use a generic picture for the entire product series.
Oh, OK. Thanks.
wrote:I mean the ones that solder onto the video card
Sorry but no cables solder on to a video card
wrote:That part does not look a thing like a 6-pin PCIe connector
6-pin PCIe connectors dont solder on to the card either
do you mean these ? (this is a 6pin connector)
He means the receptacle. The part on the video card that the cable in your picture plugs into...
ahh,
wrote:Sorry but no cables solder on to a video card […]
no, i mean this one.
I just KNEW someone would come along and try to tell me I need a cable end connector which was why I specifically stated I do NOT need the one that goes on the end of a power cable.
Although actually the one I wanted was the vertical mounted one (not right-angled).
