[Identify] old DOS date utility
First post, by konc
Hello everyone,
I do realize this is a long shot given the lack of information, still it’s my only remaining chance of finding a very old MSDOS utility. It’s of no real practical use, only has sentimental value. Back in the early 90’s every PC in my neighborhood had it and I thought it was something common, but apparently it was just a localized thing. Since then I wasn’t able to find any reference to it whatsoever and, believe me, I did try hard.
So, this little utility I’m looking for was meant to be a replacement for “cls” and we usually had it as the last line in autoexec.bat. All it did was display the date in a large font at the center, free HDD space on lower left and free memory on lower right. The following image is only a rough approximation to give an idea of what it looked like, but it is confirmed that anyone having seen it instantly recognizes it. Please consider it abstract and don’t let your thought lock to something that looks exactly like this:
1.36 KiB
More info: It is actually prettier than my lame ansi. Colors are correct, blue and cyan blocks form some sort of gradient and remind of Norton Utilities/Norton Commander colors. It’s a .COM file, really small (IF I recall correctly ~9 or ~30KB, but again don’t count on this).
Anyone who has ever seen this please contribute with some more info so we can finally find it, or at least please confirm that it ever existed 😁 As it turned out it wasn’t common at all so any information is more than welcome!
Reply 1 of 21, by konc
A year later I'm still looking for it, so this is just a bump hoping that someone will eventually recognize it. How unfortunate, having so fond memories for something you considered back then to be almost standard practice, only to find out a lot of years later it was only a "neighborhood" thing 😀
Reply 2 of 21, by BloodyCactus
i have something similiar, ill post a screenshot tonight when i get home from work! i never found anyone else useing it. mine came from a coverdisk from the uk or something.
Reply 3 of 21, by leileilol
i'll probably dig every zip i have. I recall seeing something like this on a little 1994 catalog booklet of some sort (which featured a screensaver of Bill Gates doing windows) probably not the same though
Reply 4 of 21, by konc
Wow guys, please do. It's the first time ever I get some reaction to this rough sketch. Coverdisk and 1994 sound really promising, apparently it is as unknown as something only published in a coverdisk and the year is really close to what I remember. You have no idea how many BBS archives I've downloaded from FTPs and browsed until now...
Reply 5 of 21, by BloodyCactus
this is? I've had + use this for years and years 😀
Its like 1kb; so I threw it on my site
http://mega-tokyo.com/n.com
Reply 7 of 21, by konc
Yes, yes and YES!!!!!!!!! I have no words to thank you enough, I've been searching it for unimaginable time!
It looks like my memory served me pretty well on the drawing 😀
I'm going to run it a million times now just to see it again and cry
THANK YOU!
I always thought that the "n.com" was a renamed file for shorter typing (we were using it as a cls), but even though I did search for it, nothing came up. The filename wasn't helping.
Reply 8 of 21, by BloodyCactus
no worries 😉 Once I saw your drawing I knew exactly what it was, its pretty distinct. yes I too used it as a 'cls' type tool.
Its copyright is "UK, 1990, Philema Perspectives", and I've only ever known it as "n.com", it came from a business type UK magazine coverdisk. beyond that, nothing else I remember.
Reply 10 of 21, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The program is packed with an unusual method that seems to be named "VACUUM", though it hardly needs packing given the small size. I wonder if the packing was applied originally by the developer or later by someone else, and if the packing program was ever released.
Reply 11 of 21, by BloodyCactus
as author of said packer. its called vacuum, its written in pmode asm as an exercise using dos32 extender (adam seychell version), yes it was released.
i cant check at work but I think this is it; its on stuba.sk
ftp://ftp.elf.stuba.sk/pub/pc/pack/vacuum.zip
I never wrote an unpacker since its .com, its not needed imo, its so simple.
it works, but it was an test really, not very comparable to other packers, not worth using imo! 😀 I wrote unpackers for lots of things, worked on a cpu emulator for a universal unpacker too (avoids needing int1 tricks etc).
Reply 12 of 21, by konc
So let me get this straight: not only you had this completely unknown utility, but someone used your packer on it? What are the odds, are you sure you didn't write n.com as well? 🤣
btw I'm almost sure that the n.com file I had was 8-9KBs (yes, I had it as n.com too but I didn't mention it in the first post because I thought it was renamed since there was no search result whatsoever about that filename). Can its current size be the result of said packer? If so (and since an unpacker was never available) someone other that the author did it.
edit: on second thought, maybe you run your packer on it, at some long forgotten moment!
Reply 13 of 21, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Here is the unpacked program. I also removed a piece of appended code that causes the program's display to be messed up if the default drive is A:, at least in DOSBox. There is also a string of four NOP instructions in the program that appears to be another modification, but not easy to guess what might have been there. Note that the unpacked program has a notice intended to be shown when the file is displayed with the TYPE command.
    n_unpacked.zip
    957 Bytes
    46 downloads
Reply 14 of 21, by collector
Perhaps not worth noting since it seems fixed in SVN R3972, but there is a problem with it in stock 0.74.
2.49 KiB
Which works in SVN R3972:
2.34 KiB
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 15 of 21, by keropi
interesting little util, not bad 😁
Tried it on my XT setup, it does take a while (as expected) to calculate the free space when you run it after a boot , same as the DIR command. Run N.COM once and you get this screen - nothing unusual (no battery atm so date/clock is not working properly)
Run it a second time and the prompt is no longer white:
you have to CLS to restore the color and have N.COM work OK once more for one single instance, then the color gets stuck again upon exit. Nothing big, sure , just mentioning it... 😀
Reply 16 of 21, by leileilol
For puristnesses here's N.ARJ........renamed to a ZIP so this board can take it (it's still an ARJ)
    N.ARJ.ZIP
    1.56 KiB
    45 downloads
Reply 18 of 21, by keropi
^ no ansi driver loaded at all ... nothing is getting loaded on boot tbh in this setup, at least it works OK one time so it's something 🤣
At any rate, it's a little annoying for a XT setup to be forced to wait each time for the free space calculation , I'll probably won't care about this util since I wasn't using it back then (or anything similar for that matter but I do understand completely konc's nostalgia reasons though, glad this was unearthed 😊 )
Reply 19 of 21, by konc
keropi wrote:
^ no ansi driver loaded at all ... nothing is getting loaded on boot tbh in this setup 🤣 , at least it works OK one time so it's something 🤣
You are correct, this is exactly the behavior.
-Without (DOS's) ANSI.SYS loaded: second time you run it you get the viagra look.
-With (DOS's) ANSI.SYS loaded: sorry, no viagra for you. No matter how many times you run it, prompt stays gray.
(wow again, this does pull strings. I can't describe how happy I am people are actually interested in this, trying it, unpacking it, typing it, posting the unpacked file...)
