Azarien wrote:But they are numbered, in a year-month scheme: […]
Windows 10 RTM - 1507
November Update - 1511
Anniversary Update - 1607
Creators Update - 1703
Plus there are separate build numbers in the form of 10.0.xxxxx.
True, but I was referring to numbered as increment by one every release service packs. Yeah, these are pretty much the service packs everyone is used to seeing with previous Windows versions, except that they seem to be packing enough into each release so it's practically a new Windows version with each major update.
Let's hope this doesn't lead to subscriptions for updates, which would be not much different from buying a new Windows release every few years, except they probably want you on the hook for maybe $100 every year.
KT7AGuy wrote:collector wrote:KT7AGuy wrote:Windows 10 Won’t Run Games Using SafeDisc Or Securom DRM
This is actually a good thing and can easily be worked around with a no-CD patch.
I'm just not comfortable acquiescing to an OS that requires me to use a no-CD crack to run older software. Daemon Tools is one thing, but being forced to use a crack is another thing entirely.
Of course, this sort of thing is why I'm doing my gaming/entertainment/testing on systems other than my main PC nowadays.
You're more willing to burden your operating system down with DRM crap than to patch it away?
