First post, by robertmo
- l33t++
wrote:Sounds like a brilliant idea. If desktop resolution is working (obviously), DOSBox should setup that resolution by default (as safe-mode so to say), leaving you the option of changing it when you like (by editting dosbox.conf of course).
this options was always available in DosBox:
fullfixed=true
fullresolution=0x0
