Reply 160 of 1609, by xjas
- l33t
I opened up my 3-way "SLI" machine to change some drives around and found this bit of loveliness inside:
Yeah yeah, leaky cap on a 2008 GPU. Big whoop. The thing is, I only built this machine about two months ago and it looked completely fine when it went in, so this was recent. I've run across a lot of stuff where the caps went bad in the past, and that seemingly took years of use to manifest. I've never had one go bad over the span of a couple months of moderate usage in my possession.
Granted, I did just about everything "wrong" in this build - bad airflow, shoddy cable management, inadequate cooling - and you could probably argue the cap was ready to go even if it wasn't bulging when I put it in. I didn't really make this machine with the intent of keeping it together for very long. But I also haven't used it that much, just a few ~1hr long gaming sessions and some benchmarking. This card was in the very bottom slot running PhysX, and it did get hot with the big passive cooler.
Still, it looked perfectly fine 2 months ago, and now it doesn't.
Fortunately it's pretty easy one to replace, and the other caps on the card "look" fine, so I'm just gonna leave those alone unless I need to.
