First post, by retro games 100
I don't know whether I'm going blind, or stupid, but when I browse my retro compact flash drive (has DOS on it) on my Windows 10 machine, I can't see the autoexec.bat or config.sys files on it. They are there, because I can edit them when I use the CF drive on my retro PC. In Windows 10, I have the view option set to "show hidden files", and so I'm surprised that I can't spot them. I'm sure I've made a simple mistake, and there's something simple that I have forgotten to do!
Reply 1 of 2, by andreja6
Sometimes they still get set as system files, did you try opening them with notepad using the run menu? Such as
notepad X:\autoexec.bat
Where X is the drive letter?
This ofc won't show it but it's enough to edit,
I'm not sure how Windows 10 handles things but in 98-7 you need to tell it to show system files
Reply 2 of 2, by retro games 100
Ah thanks, I forgot about the System Files attribute. Tomorrow, I will double-check this.
(At the moment, I only edit these "system files" on my retro machine.)
