First post, by Anonymous Coward
http://www.chipdb.org/data/thumbnails/113/Cyr … P_diff_logo.jpg
Does clipart exist of the original Cyrix logo with the flying 'C'?
Reply 2 of 16, by Anonymous Coward
The problem is the silkscreen on the CPU is not easy to copy because it's not clear. Maybe there are some old documents with an enlarged version.
Reply 3 of 16, by Cyrix200+
There is also this one: http://cpu.f5soft.com/details.php?image_id=16
Also not very useable for copying.
EDIT:
Ah, also in this manual. Might be more usable?
https://www.datasheetarchive.com/pdf/download … rix%2520FasMath
1982 to 2001
Reply 4 of 16, by Anonymous Coward
Maybe an old PDF document from 1988-1989 has it? I haven't seen any of those either.
Reply 5 of 16, by Cyrix200+
Cyrix200+ wrote on 2020-08-03, 11:29:
There is also this one: http://cpu.f5soft.com/details.php?image_id=16 […]
EDIT:
Think this one is better: https://www.ardent-tool.com/CPU/docs/Cyrix/387/83d87.pdf (From https://www.ardent-tool.com/CPU/Docs_Cyrix.html)
1982 to 2001
Reply 6 of 16, by VileR
3.55 KiB
Don't know why SVG isn't an allowed file type here, but there you go:
cyrix-old-svg.zip
5.75 KiB
61 downloads
(Based on: https://www.datasheetarchive.com/pdf/download … sMath%252083D87)
You're welcome
Reply 8 of 16, by Anonymous Coward
Nice! Thanks!
It's pretty close. Maybe it would look even better if there weren't dividing lines between the different sections. I will modify it later.
*edit* Done. See attachment.
    11.19 KiB
    No downloads
Reply 9 of 16, by Cyrix200+
Anonymous Coward wrote on 2020-08-03, 14:06:
Nice! Thanks!
It looks nice, but I think the dividing lines are there on the CPU silkscreen you posted?
1982 to 2001
Reply 10 of 16, by Anonymous Coward
That's true. I don't really see them in the pdf document though. It would be nice to get a high resolution shot of it. Maybe there's something in an old magazine to work with.
Reply 11 of 16, by VileR
Yeah, the fax quality of the datasheet scan makes everything look like it's joined up, but there's a slight "capping" on the horizontal lines, which sorta suggests that the circles were originally separated like in the silkscreen.
Looks a bit too close to the design in the Cirrus Logic logo. Maybe that's why they changed it? 😀
https://logonoid.com/images/cirrus-logic-logo.png
Reply 12 of 16, by Anonymous Coward
Probably. Maybe they hired the same consultant to design their logos?
I personally think it looks better on the Cyrix logo.
Reply 13 of 16, by rmay635703
When did the CCCyrix logo bite the dust?
I remember that as always being their logo yet it appears I never owned anything with the CCCyrix logo
Another oddity did Cyrix ever design 8086/286/386 Chips (excluding the SLC)
I vaguely recall them having something other than a coprocessor for sale briefly before the SLC Era but could never find mention of it.
Reply 14 of 16, by Anonymous Coward
Nope. The DLC/SLC was their first CPU as far as I am aware. Maybe you're thinking of their 8087 and 80C87 clones, which apparently existed at some point but maybe not as a consumer product.
The CCCCyrix logo appears to have been phased out in 1990. I think the reason you've never seen it is because prior before 1991 386s were just really damn expensive and rare, and not every 386 back then would have had an FPU either. They were produced in very small numbers in comparison to their later 387+ core FPUs. I think pretty much all of the CCCCyrix chips had gold tops, except for the SX FPUs which of course used PLCC.
Try to find a Cyrix chip with an 88 or 89 datecode. I can't.
Reply 15 of 16, by wiretap
I was browsing an old PC Magazine PDF from 1990 that I have in my digital archive, and came across a Cyrix ad with this logo. Sorry for the thread bump, but I thought it would be relevant and contains the slogan below the logo.
My Github
Circuit Board Repair Manuals
Reply 16 of 16, by Anonymous Coward
Very nice. Thanks. I'll use that to create a more accurate rendition.
That Fasmath box art is pretty classy. I like how in the ad it has warp engine trails like the 80's era star trek movies.
