New server
Reply 20 of 28, by Malik
I can only see the frogs images.
Reply 21 of 28, by Malik
This is what I see :
Reply 22 of 28, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
In the problem posts check whether you are using the exact same link. Otherwise its just very strange...
Oh, I see. The problem must be on your side. I see the pictures just fine.
Reply 23 of 28, by Malik
Yes, yes,yes, EXACT SAME LINKS. 😀
Reply 24 of 28, by Dominus
DOSBox Moderator
you probably didn't see my edit, but I can see the pictures just fine. Try whether deleting imageshack and vogons cookies helps. Also getting rid of your IE cache helps as well
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 25 of 28, by Malik
Ok, I'll try. Thanks!
Reply 26 of 28, by megatron-uk
Images in your posts also appear fine for me too.
https://www.target-earth.net
Reply 27 of 28, by Tetrium
Same here.
Reply 28 of 28, by Malik
Thanks for the input, guys! I think it has something to do with the "local" domain over here.
