🤣 Yeah I actually bid on a Mitsumi 1.44mb 5.25" drive quite a while ago. It's already installed in my Packard Bell.
I payed 17$ for it with shipping, so not to horribly bad and as you can see it matches the colour of the Packard perfectly.
Be it noted that I had a hard time getting it to work at first because it has a row of jumpers in the back to set various things but now that I have that figured out it works perfectly. Of course it needed to be cleaned but that should be done anyhow. 😜
Here is the drive right after I took it out of the envelope the seller sent it in. (I was quite mad that he sent it in something so light)
During the process of getting it to recognize by playing with the jumpers. It's the drive pointed at the ground hanging from the side of the case.
Finally getting it to work in Windows 98SE! God I can't tell you how happy that made me. 🤣
As you can see by dumb luck the yellowed white plastic matches the case perfectly! I couldn't believe it.
