Reply 20 of 24, by obobskivich
- l33t
wrote:consider this, when lcd monitors first came out the wisdom was you need a response time of 25ms to avoid ghosting. ips panels now do 5ms (ok so some different panels can do 1ms)
its a bit like saying 90fps is slow because some other card can do 110fps.i bet if you find out the response of your current lcd its worse than that of a new ips
And those original LCDs weren't impossible to use for gaming or video or anything either - magazines and whatnot do a very good job of making a mountain out of a mole hill. 😵
