Dominus wrote:As I wrote before the exclusion is likely because there doesn't exist THE 3dfx rig. A C64 is a set of known hardware that makes […]
As I wrote before the exclusion is likely because there doesn't exist THE 3dfx rig. A C64 is a set of known hardware that makes up the computer. A 3dfx rig is a merger of parts which could ne anything. The exclusion is thus probably not intentional but stems from the authors angle. When one starts out with
Edit, hit the wrong button, continuing...
the article describing whole machines in retro computing it's understandable to miss retro parts.
And I think this distinction is right. IMO it would make sense to have a seperate article about "retro PC parts" or ecen better seperate articles about retro PC graphics cards and retro PC sound cards.
The important thing about the 3dfx rig is the 3dfx card, the other parts aren't that important (could be an AMD or intel CPU, amount of. RAm etc.) though the article should describe what's the best combination to avoid bottlenecks.
As I mentioned before, some people will disagree with a 3DFX rig being a retro rig, but fact of the matter is that it technically is. The fact that PC computers are so flexible compared to the non-PC compatible computers doesn't change a thing.
A 3DFX rig is more flexible, but it's a retrocomputer non the less and thus logical to be included. An article about "retro parts" could be combined into an article about collecting hardware, which again could include C64 and the likes as well as standard PC collecting (especially people collecting CPU's and graphics cards).
Actually, the fact that the non-PC's are much less flexible compared to PC's only makes things worse for them. It's not for no reason that Commodore, Tandy and all those other home computers were a flop and PC's became the dominant home computer. It's because the architecture, from a retrogamer and retrocomputer hobbyist, simply are inferior to the flexible design of PC hardware.
Some might not like it, but in the end it was the PC that kicked all the other architectures (except for Apple) into extinction and thus into the history books.
As time passes retrocomputing will be more and more about PC's, weather you like it or not 😜
You can write whatever you like in the wiki but as long as you can't change the dictionary, you can't stop PC's from becoming retro and vintage anywayz.
Retrocomputing and retrogames are a part of PC history and theres no going around that. The sooner the disgrunted old goats accept that, the easier it is for them.
And even if the disgrunted old goats go as far as to delete every mention about retro PC's in the wiki articles, time isn't on their side anyway, they can't stop the inclusion of retro PC's mentioned in the wiki forever 😜
If someone wishes to write another article about retro computer parts, go ahead and write one, but that's off-topic as far as I am concerned as this thread is about retrocomputing and retrogaming, not about retro hardware (go and write it if you want 🤣).
