Originally posted by kukus444 Myst 1
The original port of the Macintosh original. 256-Color art, hard to run properly on modern machines.
Myst master piece edition
Basically, the re-release of the original. Better sound, and 24-bit graphics
A "real-time" 3D world, needs a capable 3D card (16 Megs or more), and a processor that runs at 800MHz or higher (technically at 450MHz, but really 800MHz).
I have heard that the masterpiece edition has problems with XP. So I guess the only one for you is realMyst, unless you have a dual-boot setup. They are all basically the same game.
