First post, by MiniMax
Rank Moderator
Moderator
Something I found at another forum (slighty altered to protect the blind).
jereminion Junior Member Posts: 7 dosbox help hi i need help trying to open a video game that requires dos to use..how do i […]
jereminion
Junior Member
dosbox help
hi i need help trying to open a video game that requires dos to use..how do i open the game .exe file with the dosbox? i need commands i think or something, i am totally new at this. 😜
trekkiejt Member Posts: 78 Change to the directory where the file is, type the exe file name and press enter. […]
trekkiejt
For example if it Scorched Earth:
1. Computer boots to dos or windows exited to dos, or dos emulator running and prompts "C:\>"
2. Type dir/p/w, press Enter, and look for the dirtectory name, it will look like "[SCORCH]".
3. Type "cd scorch" and press Enter.
4. Type dir/p/w, press Enter, and look for the file that ends with ".EXE" like "SCORCH.EXE".
5. Type the file name (i.e. "SCORCH") and press Enter.
6. Enjoy.
jereminion Junior Member Posts: 7 thanks for helping but can you help in this particular situation; […]
jereminion
Junior Member
directory is H
im trying to open panel.exe
directory:H:\System.Shock.2.PC.Game.
also how do i change directory, currently it is at 'Z'
elroy Ultimate Member […]
elroy
Ultimate Member
elroy's Avatar
cd\H
jereminion Junior Member Posts: 7 in responce it wrote 'Unable to change to: \h […]
jereminion
Junior Member
when i put H in upper case, it just said ch\H is an illegal command
trekkiejt Member Posts: 78 First of all the "H" is called the drive letter and the directory is what comes after the "H:\", di […]
trekkiejt
First of all the "H" is called the drive letter and the directory is what comes after the "H:\", directory equals folder. In MSDOS long names are renamed with a tilde and a number at the end making it only 8 characters. In this case you would probably type "cd system~1" after the "H:\" and press Enter. Then just type "panel" or "panel.exe" and press enter. (When you enter a name without an extension in MSDOS it looks for the extensions ".COM", ".BAT", and ".EXE", whichever comes first is the one ran.)
trekkiejt Member Posts: 78 To change to another drive just type "h:" or "h:\" and press Enter. H usually stands for a host dri […]
trekkiejt
To change to another drive just type "h:" or "h:\" and press Enter. H usually stands for a host drive or a device listed after several others.
jereminion Junior Member Posts: 7 actually i got it to change directories, but when i typed 'panel.exe', it said 'Cannot run i […]
jereminion
Junior Member
actually i got it to change directories, but when i typed 'panel.exe', it said 'Cannot run in DOS mode.'
trekkiejt Member Posts: 78 Okay, what O/S are you using? If it is 2k or XP it may not work because they do not use MSDOS. […]
trekkiejt
trekkiejt Member Posts: 78 That means it needs to be run in Windows. […]
trekkiejt
jereminion
Junior Member
i dont know what O/S means, but i am using Windows XP Professional Edition. i am aware they dont use msdos and i was seeking answers from dosbox 😳
jereminion Junior Member […]
jereminion
Junior Member
yes it works in windows, but when i try to install the game, it says 'C\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the application. When i press 'Ignore' instead of 'Close', it just closes the installation anyhow.
trekkiejt Member Posts: 78 O/S is Operating System which in you case is Windows XP Professional Edition. Sorry I thought you w […]
trekkiejt
O/S is Operating System which in you case is Windows XP Professional Edition. Sorry I thought you were using MSDOS on a "DOS Box" as in a "DOS only machine" and not a DOS emulator. Other terms like it include "Winbox", "Linbox", "Mepisbox", "Macbox", etc..
Is the game on a CD or a Hard Drive?
Find More Posts by trekkiejt
jereminion Junior Member the game is on hard drive […]
jereminion
Junior Member
bazcor Member […]
bazcor
TAke a look at this... http://unodocs.nmsu.edu/RoboDocs/Web...ator/ji_05.htm
Sometimes the autoexec.nt (text) file just vanishes, happened to me a few months ago.
_________________
Reply 1 of 4, by DosFreak
Yeah, only solution for these types of people (not considering putting them out of their misery of course) are services like GameTap or perhaps prepackaged DOS games with a DosBox PhysFS enabled build with a frontend already setup for them.
Otherwise we'll just keep on going this crap over and over and over and over....fun isn't it?
Of course I've noticed that if I ignore these stupid questions eventually one of the newer members of VOGONS will answer the question or if I'm feeling particularly charitable I may help out but it really does waste alot of time.
It looks like the new equvalent in Vista to the 2K/XP "'C\WINDOWS\SYSTEM32\AUTOEXEC.NT" problem is the "Unable to run in fullscreen mode". This leads people to believe that there is something wrong with their computer, that needs to be fixed. When the fact is that the command prompt cannot be run in fullscreen mode with WDDM drivers.
I hate Microsoft.
Let me rephrase that.
I REALLY hate Microsoft.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 4, by 5u3
Well, at least they were polite and able to express themselves in acceptable sentences. In my opinion a false hint is not that bad if someone more experienced can at least read the whole thing and figure out what's going on. 😉
What I hate most are those "HELP!!! game no work WTF?!" posts. Even if someone tries to decypher such garbage, it usually turns out that the one who asks is not really interested anyway.
Reply 3 of 4, by Miki Maus
OK, I may be of, but what's wrong with drag'n'drop game exe on Dosbox icon? I didn't see anybody recommending it.
Altough I'm experienced user I find it easier than typing commands and such. Most of the games work that way without much tampering. 😀
Reply 4 of 4, by Kreshna Aryaguna Nurzaman
😳 You gotta' be kidding.... 😳
Kreshna Aryaguna Nurzaman.
