Originally posted by Duffman I finally managed to partition my harddrive so I could install windows 98.
But when I try to install it, it want to remove my NT-based operating system.
What? No, no, no...something's not right here. All it should do is give a warning that Win98 doesn't support (can't read) NTFS partitions, but it shouldn't block you from installing or "try to remove" your NTFS partitions.
How do I install windows 98 on a primary DOS partition that isnt C:?
DON'T. Give it the C: drive, that's where it was meant to be... 2000/XP don't really care about their drive letter.
Is there a way to change the drive letter C to another letter, and then make my DOS partition C:?
You mean change your XP partition's drive letter? No. It will say as C:\ as long as you're running XP, it will give the next freely available drive letter to your Win98 partition. It's not going to "hurt" your Win98 partition, it's just that the Win98 partition will C:\ when you are running it, but something else when you're running XP (which is why its wise to label it something like Win98 for easy identification).
Originally posted by Snover You'll need to remap the partitions. Windows XP doesn't mind being on something other than C:
True, unfortunately it won't let you change the drive letter of your boot partition (for XP) as long as it's running. And since it must be running for you to change the drive letter... unless someone knows of a trick in the Non-GUI admin mode?
...but Windows 9x will freak out on you and do, well, what you're describing.
Correct. Win9x wants C:\, give it C:\
Originally posted by DosFreak 9x is fine on ANY partition (drive letter).
BAD idea. This is only works if you remember a large number of caveats. Everything in Windows 9x follows a certain template. You split it up between two partitions an you are just begging for trouble.
Windows programs will attempt to install to both partitions (C:\Windows and D:\Windows), same way with programs in general (C:\Program Files and D:\Program Files). Some programs simply presume C:\ and will break if you try to place them elsewhere.
Almost no benefits and plenty of potential headaches. Let Win98 install its files where they normally go (and keep them there). The only exception to this would the Windows directory itself. I recommend that one of the two OS's (*pssst* Win98) be installed to a directory named "W" (or some other 8-character-or-less filename) instead of "Windows.
You will still get an occasional glitch for Windows install on Win98, but they can be fixed by moving whatever files you find in the "Windows" directory to your "W" directory (then deleting the installer-created Windows directory).
Why? It reduces the risk that a program on your XP side will attempt place it's file in your Win98 directory. Yes, I know, 2000/XP installers won't do that, but installers for older Windows tools that you want to run from within XP will sometimes do it.
Originally posted by Duffman I now have to repair windows XP.
You shouldn't do that. Install Win98 on the first partition. Then when it's working properly, you use the re-install trick to set up the dual boot.
You would think the giant "Microsoft" would have found an easier way to run multiple OSs by now.
Actually, there's a very easy way of doing it. You have to install Win98 first, make sure you have some empty space on the drive (an unused or unwanted partition), you then install XP as a "new install" (NOT upgrade).
XP sets the dual-boot and it's menu for you. It's trying to install Win98 after XP that's a massive pain.
