very big problem
First post, by abyss
I just get a 7 inch album ELO Street Talking Women but how do I play it on my record player. I have several 12 inch records for it and know how to play them. My record player has an option for 45 rpm speed which is the speed I think the 7 inch albums play at. There is a hole in the middle and I can't put the needle over it as the hole is too big. What do I need to do.
Reply 2 of 14, by abyss
Isn't it very old gramophones on new systems.
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
Nope, but good point 😀
Reply 4 of 14, by tannerstevo
you need an adapter like this:
Reply 5 of 14, by MiniMax
Rank Moderator
Moderator
http://www.amazon.com/Plastic-45rpm-Record-Ad … y/dp/B000PJJX5O
http://www.lpgear.com/Merchant2/merchant.mvc? … tegory_Code=PTS
_________________
Reply 6 of 14, by Moogle!
New old stock in delightfully yellow eye-catching color.
Reply 7 of 14, by akula65
Many turntables come with a 45-rpm adapter that you place on/over the small protrusion on which you place a 33-rpm album. You might check your turntable manual or the box that your turntable came in and see if you have misplaced it.
Reply 8 of 14, by Snover
The topic is misleading. 'Very big problem' would be something like "my printer is on fire, how do I extinguish the flames? I only have a paperclip, some duct tape, and a Barry Manilow LP". This is more like "how can I avoid using Google?"
Yes, it’s my fault.
Reply 9 of 14, by Moogle!
Error: lp0 medium size mismatch
There are very few threads on this board that can't be solved by Google. No where does it say in the description for Milliways that discussion has to be computer related.
Reply 10 of 14, by WolverineDK
Sir, abyss is known for having more ramblings than me. And that is a lot.
And his threads makes less sense than my posts can do in the long run.
Reply 11 of 14, by Kreshna Aryaguna Nurzaman
Actually the thread in itself makes sense: asking how to play a certain 7" record on an incompatible turntable.
The way he asked it, however, still makes my head explodes, not to mention the horribly non-descriptive thread title. 😉
Kreshna Aryaguna Nurzaman.
Reply 12 of 14, by Kippesoep
Who needs Google? A drafting compass, a sharp knife and a piece of cardboard or similar would suffice.
My site: Ramblings on mostly tech stuff.
Reply 13 of 14, by abyss
Wow it worked I can play 45 rpm 7 inch records.
Reply 14 of 14, by WolverineDK
What do you want ? a cookie ? I love LPs, but there are boards where you can get the answer easily without the BS that runs with it here. Heck I even believe that wikipedia could have told you what you were looking for in the "problem".
