First post, by Abson
I'm hoping someone can help me here. I got the soundcard off of ebay, and the problem is that when 16-bit sound is played, the sound is horribly distorted, be it in pure dos mode or windows 98. 8-bit sound is fine. I'm not sure if it's driver related or not. I ran the diagnose program in pure dos and when I get to test the 16-bit sound samples, the sound is distorted... The only thing I haven't tried is moving the sound card to the other isa slot, other than that, I don't know what else to do. Is the sound card broken perhaps? The jacks on the back are also a bit different, I have to connect speakers or earphones to the 2 red and white RCA jacks on the back using a splitter, otherwise I don't get any sound using the line in jack, unless I am suppose to be using that, but need to have a cable connected to the soundcard inside the case or something? Any help would be really great. Thank you!
