First post, by RogueTrip2012
I've been looking around for awhile for a way to run a USB gamepad in a dos window for games like Carmageddon 1 series. After searching google there was a program called joytokey but that didn't work for me. Anything else I can try?
Specs:
*USB-2-Playstation2 adapter with genuine sony PS2 controller
*Windows 98SE
*Add-in USB 2.0 4-port PCI card
I also have a original MS Sidewinder (gameport connector) but and worked 1 time in carmageddon for about a minute or two and then lost the controller. probably the digital emulation issue.
Reply 2 of 3, by RogueTrip2012
I never had a proper Gameport gamepad so I wouldn't know how awesome carmageddon would be to play without the keyboard.
Been looiking around and found a few emulation programs and see one of the programs has a TSR setup. Will have to get around to checking it out.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
Reply 3 of 3, by RogueTrip2012
*UPDATE*
I got it working!! Working well in Carmageddon Splat pack.
JoytoKey does work. Found you need to set the Auto key to max otherwise it only sees each input as a single stroke. Still need to tweak jtk a bit more but atleast it is working!
