First post, by 7cjbill2
Uploaded with ImageShack.us
GeForce 6800 Ultra OC PCIe
Would like the most "modern" recommendation but also fairly budget. I've got my 2xVoodoo2 cards for SLI GLide stuff....supercool if I could find a MoBo w/ 66MHz PCI slots.
Pentium build about to go into completion stage.
386 build about to go into construction stage.
486 re-build about to go into collection stage.
Retro-semi-modern about to go into planning stage. 😀
Will pay $$$ for:
caching ISA I/O-IDE controller
PM me for my list of trade-ables...
Reply 1 of 13, by jaqie
it's a royal shame that isn't AGP... the 6800 was the last native AGP chip nvidia made to my knowledge.
The earliest PCIe systems I know of are socket 939 systems, that's when I went to PCIe... they are kinda expensive though to put together.
If you want PCIe and PCIX you will need to go directly to workstation boards which means you're likely to get into very spendy stuff.
Reply 2 of 13, by 7cjbill2
Yeah, if it were an AGP I'd have a couple nice MoBo's to throw at it. I've got a 939 DUAL MoBo PC sitting here, but I use it to run my Wildcat 800 + VP2290b so I'd like to keep that in situ...
Will pay $$$ for:
Reply 3 of 13, by jaqie
erm... socket 939 isn't SMP capable. That was socket 940. I know, I have a board here that is dual 940, and several extra opteron cpus, along with having given another dual socket 940 system to a friend that loves opterons.
Reply 4 of 13, by 7cjbill2
Not dual CPU, a 939 DUAL board has both AGP 8x and PCIe 16x slots...
Will pay $$$ for:
Reply 5 of 13, by jaqie
oh jeez. those are kinda oddities, not seen so many of those.
Now that I think about it, your second best bet would be an am2 single core based system, I think.
Reply 6 of 13, by Gemini000
Waitaminute... Does Windows 98 even support PCIe? I already know it tends to have issues with USB 2.0...
Also, just as additional info, I'm 99.9911254% positive that Windows 98 can't handle dual-core or dual-cpu systems properly. :P
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 7 of 13, by jaqie
It can handle them, it just runs on the BSP and ignores any APs, so it does not fully utilize them but it works fine. I did suggest a single core am2 system, however.
I have no idea if it can handle PCIe properly, however.
Reply 8 of 13, by F2bnp
I don't think Win98 works with PCIE unfortunately.
Dual Core/Processor or HyperThreading works fine in Win98, the OS just doesn't make any use of it.
Reply 9 of 13, by sliderider
You won't build a Win98 machine around that because it's PCIe and Win98 does not have PCIe support. You would need an AGP version of that card to use Win98.
Reply 10 of 13, by 7cjbill2
Bummer...may have to drop back and punt on this one.
Will pay $$$ for:
Reply 12 of 13, by prophase_j
Depending on the motherboard... you might be okay. Look here:
Compatible Hardware with Windows 9x
and here:
Modern motherboards which are working with Windows 98
(edit) and one more:
Nvidia PCI-E GeForce series 6 cards in Windows 98
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 13 of 13, by 7cjbill2
I will probably just hunt down an AGP version when the time comes, and I can toss it into my D850GB board or VC820 at the worst. My card is 512MB anyway, not sure that would even work with W98.
Will pay $$$ for:
