First post, by badmojo
- l33t
I want in on the Roland midi bandwaggon - countless years too late I know, but that's just the way I roll apparently.
So I've been working away on this project for a while and have managed to put together a 386DX40 machine to play pre general-midi games on. I haven't been able to track down a MPU-401 interface card for a reasonable price, but my plan is:
- Roland MT-32 (see below)
- Ensoniq soundscape, first version. My understanding is that this thing does a decent job of emulating "intelligent" mode MPU-401.
- Joystick to MIDI cable from the Soundscape to the MT-32 (see below)
- Sound blaster pro 2.0 for OPL and digital effects.
- 3.5mm STEREO Jack to 2x 6.35mm MONO Male Plugs Cable
I'm still waiting on the 3.5mm stereo to 6.35mm cable but I'm thinking I can plug the 2x mono plugs into the MT-32, and the other end into the 'line in' of the SB Pro, then the line out of the SB Pro into my amp; effectivley using the SB as a mixer.
But will this work?
And will I need any drivers installed to use the Soundscape's MIDI port? I have it jumpered to 330, and I'm hoping that's enough. I don't think that conflicts with the SB Pro in any way?
Pics:
The MT-32, power supply, and joystick to MIDI cable. I'll need an adapter for the power supply to fit an Australian socket, but it is the correct voltage at least (it's from the U.K).
Close up. It's a very clean unit, obviously used but well cared for.
Documentation it came with.
Thought I'd include a pic of this nice case while I was taking photos. I found it at the tip a while back, and it was pretty much brand new. There was some socket 7 rubbish in there which I've since dumped for a nice 486DX2-66 setup. This is my general midi era machine (pre Windows 95 that is... I have another machine for that - this hobby is getting a little out of hand)
