ratfink wrote:In my windows 7 box i have a xonar sound card with headphone amp. I use it with some Phillips headphones. […]
Normally it is great but the other day in WoW the sound degenerated into crackling for a while.
My previous box [completely different mobo, vga, cpu, ram] used to do this - i had assumed it was some problem with onboard sound.
Any ideas?
Make sure you rule out your headphones first. I was running into sound problems and couldn't figure out whas was going on, then one day while taking my headphones off I had touched the wire for one of the speakers in just the right spot for it to feel wrong. I took a look and the cable was indeed separating from the speaker plug. x_x;
Got a replacement cable and everything's been fine since. :)
Beyond that, crackling problems are usually related to outdated drivers, so make sure you update your audio drivers. If that doesn't solve them, the other possibilities I can think of are device conflicts, interference from other electronics, or heck, the audio device itself may have a bad capacitor or something. That's what took out my last LCD monitor. :P
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
