First post, by ratfink
This is driving me nuts. I have two pc's each with a phenom ii x4 965 @3.4ghz.
PC #1:
Sapphire am2rd790 board
Windows 7 64 bit
superpii runs in c. 20-21 seconds
PC #2
Asrock alivedual-esata2
Windows xp 32-bit
superpii runs in c. 26-27 seconds
Surely this is too great a difference?
I have tried restting bios on the asrock board, varying memory speed, nothing makes much difference.
Any ideas?
Reply 2 of 8, by cdoublejj
F2bnp wrote:
The 64bit OS probably makes most of the difference in speed.
This is my random shot in the dark guess. Perhaps windows 7 being a newer OS takes better advantage of the hardware.
Reply 4 of 8, by Aideka
Quote from AsRock site: "If you use AM3 / AM2+ CPU on AM2 chipset motherboard, the system bus speed will downgrade from HT3.0 (5200 MT/s) to HT1.0 (2000 MT/s), but the CPU frequency will not be influenced." If the HT bus really is downclocked that much, well it seems that there is your problem.
Reply 5 of 8, by ratfink
I'm running the same superpii on each so it must be a 32bit program. What I see on the web is that running 32bit software on a 64bit OS might give a small performance drop.
And other reports seem to show 7 is not significantly faster than xp [some evidence of the reverse I think].
I was wondering if it could be the chipset. The NB frequency on the asrock is 1600mhz, its 2ghz on the sapphire.
edit: thanks aideka, I never really understood what that meant but assumed it would be true for any am3 cpu used in an am2/2+ board. But in fact the sapphire page says: "AMD 790FX chipset based PCs feature the latest HT3 2000MHz bus technology".
Guess that clinches it, it's the chipset.
Reply 7 of 8, by Mau1wurf1977
Use a linux / Windows live CD to rule out software differences?
My YouTube channel
Reply 8 of 8, by ratfink
Yeah I could try that. I've just bought a new asus 790fx board to replace the asrock one 😁 .
edit: wow, new mobo gives superpii at 20.7, and 3dmark1001se gives 46k compared to 33-34k before.
