as mentioned, I did try fiddling with the BIOS settings... I remembered the trick of disabling AHCI from the pre-SP3 days, but this time it didn't do me any good, neither with BartPE nor with UBCD4win.
though I'm happy to say I've rescued most of my important stuff. Parted Magic did the trick: finally got it to boot up after I blacklisted some problematic video driver, and it saw both SATA drives just fine. As for the bad disk, 95% of the crucial data was on the non-OS partition, and luckily I managed to grab it all without a single error.
The filesystem on the OS partition (C:) is fritzed though. Directories showing up empty, most files reported as 0 bytes, virtually nothing that can be copied correctly. Will try some more diagnostics, but this still stinks of physical failure somewhere... so I guess this drive is destined for the dumpster.
On the upside, it's an excuse to be dragged kicking and screaming into the windows 7 age. ;)
