Reply 20 of 31, by sunaiac
Plasma pros :
- much better contrast thanks to blabk blacks
- much better response time
Plasmas cons:
- lifetime
- hot !
- glossy 😖
- carefull not letting still iamges on it. Yep, even now.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 21 of 31, by robertmo
Plasmas cons:
- lifetime - use it for high response requiring applications (games/movies) only
- hot - good in winter and on north/south pole 😉
- glossy - hdr is a feature 😉
- carefull not letting still iamges on it. Yep, even now - check point one
Reply 22 of 31, by sunaiac
Lifetime and marking problems are two different things 😉
Whatever you use it on, plasma cells lose their gaz after some time, IIRC.
Reply 23 of 31, by robertmo
it is the same: phosphor dies out
I don't think so 😉
Reply 24 of 31, by rgart
response time, input lag, less bleeding and blur, whiter whites, deeper blacks. Yes the heat generated by a plasma is great in winter or on a cold night 😀
I think led picture quality is super bright and unrealistic.
I just sold a 58 inch VT20A plasma - Panasonic's 2010 flagship model and when i loaded Skyrim on that for the first time my jaw dropped. It had amazing picture quality.
As for image retention or screen burn I have never had it happen even with my first gen Samsung plasma. I just need it to last a solid 5 years and ill upgrade.
Play Skyrim on a Panasonic VT20A and you will be converted 😀
The one thing i dislike is power consumption due to Australia having some of the highest electricity prices in the world.
Reply 27 of 31, by sliderider
robertmo wrote:
I thought Australia has the cheapest coal in the world.
Yeah but it's for export only. The enviro-loons have practically made it illegal to use just like in every other industrialized country that they are trying to cast back into a pre-industrial age.
Reply 28 of 31, by Great Hierophant
Plasma TVs are generally thicker than LCDs and use more energy. They are generally less bright than an LCD. On the other hand, they are cheaper as you get more expensive and display the full resolution with 3D enhanced material. LCDs cannot show as resolution in 3D motion.
Reply 29 of 31, by luckybob
If you're going to do something stupid like play games on a tv, you might as well just get a PS3 and play skyrim on that.
You want to unleash shyrim? play on one of these: http://www.ebay.com/itm/160993969961
Mine is powered by an ati 7970, glorious card. great framerate even at 2560x1600 max settings.
Reply 30 of 31, by Malik
Two of my gaming systems - one is XP and another is a PII system - are connected to my LCD TV, in addition to the PS3, PSOne, and the cable tv set.
