First post, by Pingaloka
- Member
Just as Socket 7 MOBOS are becoming subject of conversation lately..I have the chance to get these 4 mobos for 24 euros in total. Together or separately. I'd like to know what do you people think of them. And if they are worth getting. Let's discuss the technological and practical aspects of each of them, if they are worth the time of course!
I know Mau1wurf1977 will enjoy this one as a fan of SS7 boards.
Here they go:
a) Socket 7 CHAINTECH 5TTM1 M201
Chipset: i82430TX
Cache: 512KB
Form factor: ATX
Bus Speed: 50 / 55 / 60 / 66 / 68 / 75 MHz
Clock Multipliers: 1.5x / 2.0x / 2.5x / 3.0x / 3.5x
Voltages Supported: 2.8 / 2.9 / 3.2 / 3.38 / 3.5
RAM Slots: 4 72pin SIMM Slots (EDO/FPM)
2 168pin DIMM Slots (EDO/SDRAM)
b) Socket 7 FIC PA-2010+
Chipset: VIA 580VP
Cache: 512KB
Form Factor: ATX (w/ AT & ATX P/S Connectors)
BUS Speeds: 50 / 55 / 60 / 66 / 75 / 83 MHz
Voltages Supported: 2.8v / 2.9v / 3.2v / 3.3v / 3.52v
2 168pin DIMM Slots (SDRAM/EDO/FPM)
c) SS7 Superb 1 - QDI
Chipset: SiS 530
Form factor: microATX
Bus Speed: 100/95/83/75/66MHz
Clock Multipliers: x2 up to x5.5
Voltages Supported: 1.3 to 3.5v
Onboard Audio CS4235 audio chip
System Memory Two 3.3V 168 Pin unbuffered 100/66MHz DIMM slots
Support up to 1GB SDRAM
d) SS7 k6xv3+ 66
Chipset: VIA®MVP3 AGP system chipset
Cache: 512KB/1MB L2 Cache
Bus Speed: 100/95/83/75/66/60MHz
Clock Multipliers: x1.5 up to x5.5
Voltages Supported: 2.0 to 3.5v
16MB to 384MB memory using unbuffered DIMMs
Three 168-pin DIMM sockets
PC-100 SDRAM DIMM for 100MHz external system bus clock
processors
ECC suppor ted (uses x72 PC SDRAM DIMM)
