To be clear, there's no 64-bit or Windows 7 support for those, is there?
No, they were obsolete long before Win7 came around. For SD capture, I don't know of any really good cards (at least, with a reasonable price tag) that support 64-bit. With these things, newer does not mean better. Everything now focuses on digital tuners and/or HD capture, with composite/SVideo tending to be more of an afterthought... and it shows in the quality of the captures.
Actually, I think the best quality option would be one of the old AGP AIW cards with the Theater 200 chip. The capture quality on those things can compete with a lot of pro-class cards. Capture into lossless AVI using your codec of choice ( HuffYUV or Lagarith being the most popular), and then edit and re-encode to whatever format you want from there.
But for most purposes, that's overkill. I would consider the Hauppauge PVR cards to be second best... you don't get the option of lossless capture, but most people are just going to be transferring to DVD or posting on Youtube anyway, so MPEG-2 is fine. And, unlike the old AIW cards, you're not limited to using a system with AGP.
