First post, by mr_bigmouth_502
- Oldbie
I know I've been asking a lot of questions here lately, 🤣 but this is something I've been needing to know. I know that my case (a Cooler Master Storm Scout 😁) has a filter on the bottom, so this sort of implies that I should mount my power supply with the fan facing towards the bottom, but with the last power supply I did that with, I believe that the lack of airflow caused by this may have ended up killing it. So what I'm wondering is, is it a good idea to point it upwards instead? I know that in older cases, the power supply fan would normally be pointed towards the CPU in order to help cool it, so I can't see any harm in pointing the fan upwards toward my other components.
