First post, by mr_bigmouth_502
- Oldbie
I'm getting extremely fed up with trying to compile an ogg-compatible 32-bit build of DosBox so that I can play the GoG release of Carmageddon on Linux with the CD Audio. Is there a way I can convert the .dat, .gog, and .ogg files into a standard .bin/.cue image that I can use with a stock build of DosBox, without burning a CD and re-ripping it?
