Why does windows 7's audio suck?
First post, by DracoNihil
Specifically I recently ended up having to use alchmey for almost everything imaginable, because Windows 7 ends up chopping and skipping the audio otherwise.
And to add insult to injury if I try to record audio in my games through "What U Hear" it's all COMPLETELY distorted....
Tried googling, came up nothing... So I guess I have to install windows xp on this machine just to beable to record videos again, or is there a way to hack the stupid brain damaged windows 7 audio to have a SHORTER buffer like KMixer had?
― Κυνικός Δράκων
Reply 1 of 21, by Mau1wurf1977
There could be a million reasons for your issues, however I don't have any of them 😀
In my gaming / work / video editing machine I have a Sound Blaster Z and use the headphone surround for Battlefield 4. Works very well, although the technology doesn't process distinguishing sounds that come from above or below. Pretty sure EAX/CMSS-3D games under XP supported this.
On my capture PC I have a Sound Blaster Titanium HD and often use the "What you hear" to capture footage and audio mix from my retro gear.
My YouTube channel
Reply 2 of 21, by Shagittarius
Some audio cards input jacks are configurable to split between microphone and an unamplified input. If your card is one of these cards make sure you're not set to mic on the jack or it will amplify and probably distort. I had this issue with My Sound Blaster Z.
Reply 4 of 21, by leileilol
Windows 7 handles audio differently (and annoyingly too i'd admit, with audiodg taking up a lot of the processes just to equalize volume dynamically in the most undesired situations)
You'll have to configure your recording device to be your stereo mix in the sound device panel and then adjust your volume for that recording to avoid distortion. It's not really the same as going in sndvol32 and muting all but "What U hear" or 'Stereo Mix" but WorksForMe(TM).
Reply 5 of 21, by DracoNihil
I just somehow fixed it by restarting the ENTIRE audio service... but it wasn't long before the problem came back a few hours later.
and by distortion I mean, it's like it's under running somehow. Something that can easily be fixed if the stupid audio buffering in Windows 7 was not hardcoded.
EDIT: Oh yeah what leilei just mentioned, why can you not turn off the stupid dynamic compression crap that Windows 7's audio tries to do to equalize and avoid distortion? It screws with my hearing... Another reason why I've been using ASIO4ALL and OpenAL + ALchemy for anything I can use it on.
― Κυνικός Δράκων
Reply 6 of 21, by collector
Since you mention "What U Hear" I assume that you are using a Creative card. I used to have some of the issues you mention with my old Audigy, which I kept for easy use of SoundFonts. I fixed it by installing an unofficial driver pack since Creative had washed their hands of the issues on Win7. http://nomoregoatsoup.wordpress.com/2010/04/2 … pport-pack-3-8/
Reply 7 of 21, by DracoNihil
That's what I'm using... it makes no difference other than the fact Daniel K's driver seems to make ALchemy work better in almost everything on my system.
Oh yeah I remember mentioning on this forum a long time ago about a bug where if I load any kind of large sound font I get clicking when it attempts to play a instrument ONCE, and it goes away when you play it again. I'm not sure if it's this crappy OS or my card is defective.
EDIT: Also no thanks to "Hollywood" which should be burned to the ground for attacking every filesharing site that people LEGITIMATELY USE... Hotfile nolonger exists so I'm having a hard time finding Daniel K's work as a result of this... Man I hate american copyright laws and lawyers.
― Κυνικός Δράκων
Reply 9 of 21, by DracoNihil
I don't think this hotfix relates to anything I'm talking about... I said that it sounds like a underrun issue, infact if I look in Audacity I can see it's dropping samples. Restarting the audio service clears it up only temporarily. The sampling rate of the What U Hear is set to the native rate my X-Fi card records at.
Also if I recorded normal audio as in, not through OpenAL via What U Hear it sounds fine, but OpenAL or ASIO4ALL results in a stupid underrun stuttering mess.
― Κυνικός Δράκων
Reply 10 of 21, by bloodbat
Creative includes its own ASIO, it sounds logical ASIO4ALL underruns.
Reply 11 of 21, by jwt27
This is the main reason I'm still on XP. Have you also noticed that Win7 uses a very low quality resampling algorithm to convert EVERYTHING to its master sampling rate?
Reply 12 of 21, by DracoNihil
Creative's ASIO doesn't work at all, even still it's nothing to do with ASIO4ALL... I'm saying Windows Audio fails at retrieving What U Hear when I'm using a ultra low latency output source. I wish there was a way to actually pull the What U Hear of my X-Fi directly rather than going through Windows Audio.
Am I really this bad at explaining things? I wonder that myself sometimes... My audio output is fine with no underrunning, skipping or popping. It's recording it from What U Hear when using either OpenAL or ASIO4ALL as a output. If I stuck with Windows Audio\DirectSound it's fine to record. Of course I'm able to fix the stupid problem by going into services.msc and restarting the entire Windows Audio Service (which shouldn't even exist, what the hell was wrong with sound being a kernel level thing?) but this only lasts for a few hours...
Yeah, it's why I use OpenAL for everything because my X-Fi does a better job at resampling than anything software.
― Κυνικός Δράκων
Reply 13 of 21, by cdoublejj
interesting. i've never had any audio problems on 7 and i'v installed it and used on a TON of systems. my main machine sounds smooth and clear but, i have a Xonar D1 with unofficial drivers. (way better and more stable than supplied drivers)
is it really software and not hardware? maybe a few bad caps on the sound card or onboard audio? or am i totally talking out of my ass and need to leave?
does win 8 have the same problem as 7? does this problem occur with nice sound cards? can the sound quality in general be turned up? in know there is that one setting in control panel.
Reply 14 of 21, by NJRoadfan
Creative's ASIO driver works fine in both Reason and with a Winamp ASIO output plug-in for me. The card in question is a X-Fi Fatality PCI Platinum Whatever. The "What-U-Hear" input seems to work fine with recording ASIO output. Note, ASIO4ALL is an "emulated" driver, it uses your WaveOut driver for output anyway. Its purpose is to give cards that don't have an ASIO driver the ability to use the interface. Only the Creative driver bypasses the internal mixer/sampler in Windows and goes directly to the hardware.
I'd suggest trying WASAPI for direct audio device access, but it depends on what Creative driver you have installed. WASAPI enabled drivers completely remove the "What-U-Hear" input and uses its internal loopback recording device.
Any more information about the machine the card is in and what bus it uses (PCI or PCIe)? Creative's hardware is notorious for weird latency issues, particularly with non-Intel chipsets.
Reply 15 of 21, by DracoNihil
ASIO4ALL uses "Kernel Streaming", which is why you have to have absolutely nothing else using software audio processing for it to work properly. I'm going to guess because of that it bypasses Windows' audio resampler. Also believe it or not, that actually provides the best low latency and quality compared to what the Creative ASIO driver does in OpenMPT...
I also question the claim of WASAPI being able to directly access the audio device, is it even possible of using voices on a Creative sound device? WASAPI to me sounds just like what ASIO4ALL does, kernel streaming when placed in "exclusive mode".
― Κυνικός Δράκων
Reply 17 of 21, by DracoNihil
Seeing how I struggle with getting drivers of any kind to work on this system, it's probably the reason why it's not working for me properly.
I figured out how to get the Creative ASIO to work in OpenMPT (I feel kind of embarrassed for not figuring this out sooner) but I'm running into oddities with it that I don't encounter using ASIO4ALL's kernel streaming method. (being limited to 96000 when I know this card can do 192000 and frequent underrunning)
― Κυνικός Δράκων
Reply 18 of 21, by NJRoadfan
Managed to reproduce the problem. Seems like its the X-Fi driver. Re-starting the Windows Audio Endpoint service usually fixes it. It is NOT an isolated KStreamer, ASIO, or buffer issue. When the problem happens, I get distorted recordings from "What-U-Hear" with even system sounds playing back.
Check this out: http://forum.audacityteam.org/viewtopic.php?f=46&t=64544
Reply 19 of 21, by DracoNihil
Yeah exactly, I have to restart that retarded service just to fix the problem but it's temporary... Sometimes I wish Creative would just open source their drivers so someone with a actual brain can produce something that works...
― Κυνικός Δράκων
