Help with voodoo2 ebay sale
First post, by Soupdragon
I sold and sent 2 voodoo 2 12mb 3d addon cards via ebay. The buyer now claims there only 8mb boards and wants to keep the cards and me give him a partial refund. I am pretty sure they where 12mb boards, I bought them from the states as new old stock a couple of years ago. Did anyone else buy any the seller in the states had many for sale back then. They were the black STB black magic 3d boards.
Steam | World of Warcraft
Reply 1 of 21, by Robin4
The card doesnt have one total memory.. Its uses two partitions.. one is 8MB+ 4MB.. (total of 12MB)
Reply 2 of 21, by Soupdragon
yes I know 4mb frame buffer and 8mb texture memory, the guy is saying its the 4mb 4mb version
Reply 3 of 21, by Robin4
ask for a screenshot?
Reply 4 of 21, by Soupdragon
Good suggestion, I have done so and I am awaiting his response. Also I just found photos I took while I was trying to sell the cards as part of a PC that show the ram chips on the back of the cards. So now I am 100% they are 12MB cards (he had me doubting for a second). As the 8MB cards have 8 missing chips on the back of each card. I don't know if the guy is trying to con me or he’s just uninformed.
Reply 5 of 21, by RacoonRider
Post not relevant anymore >> Did it have memory chips on both sides? If yes, than it's definitely a 12MB card. Otherwise, your buyer is right.
Reply 6 of 21, by Soupdragon
Each card has 12 half meg chips on each side. I have just seen he uploaded a photo he took of dxdiag showing 16mb. Its been along time but I think dxdiag isn't very accurate in this area. I have asked him to check the voodoo2 system info tab of display properties.
Reply 7 of 21, by sliderider
I bought a pair of STB BlackMagic cards from a seller who pulled a bunch of them out of some arcade machines. If that's the seller you mean,they were definitely 12mb cards that were shipped to me.
Reply 8 of 21, by Soupdragon
He is still asking for a partial refund and wants to keep the card. I don't what to refund anything without getting the cards back as I know these cards are 12mb. I have asked him to photo the back of the cards and upload them to ebay. I don't think he is going to except there 12mb cards no matter what I do. Will ebay look at the photos and do there own research or will they just rule in his favor without checking anything? At the moment paypal have forzen my funds for this. 🙁
Reply 9 of 21, by vetz
He probably either only sees this in his driver settings and believe they are 8MB cards:
download/file.php?id=10129 From this post: (Voodoo2 SLI)
-OR-
He is using earlier drivers that do NOT sum up the memory as Subhuman@gtx explained very well in this post: Voodoo 2 sli with windows me :
What you are seeing is actually how it should really be , because Voodoo2's control panel info doesn't sum up the total amount o […]
What you are seeing is actually how it should really be , because Voodoo2's control panel info doesn't sum up the total amount of Framebuffer memory obtained from SLI. it just displays the info of a single card, not the two. That's why it says Frame Buffer Memory: 4 MB
Besides that, texture memory is mirrored on SLI, because workload is splitted between the two cards; so if you have Two 8mb Voodoo2 the total usable texture mem is of 4MB, and with Two 12mb Voodoo2 then it is of 8MB 😉 There's absolutely nothing wrong with your Athlon or WinME 😀
Example:
Voodoo2 8mb SLI:
Scanline Interleave: Detected!!
FBI Revision: x
Texture Mapping Unit(s): 2
TMU Revision: x
Total Texture Memory: 4 MB
Voodoo2 12mb SLI:
FBI Revision: x
TMU Revision: x
Total Texture Memory: 8 MB
Hope this clears things up 😁
Subhuman
Reply 10 of 21, by Soupdragon
He seems unwilling to do anything to check my claims that the card are 12mb. I just hope ebay will step in if he can upload photos of the back of the cards.
Reply 11 of 21, by vetz
I'll check my dxdiag settings when I get back home and upload a comparison screenshot from my Compaq with 12MB SLI cards.
Reply 13 of 21, by sliderider
This buyer sounds like he's going to be difficult no matter what you do.Tell him to ship the cards back for a refund. If he refuses, then when ebay gets involved tell them you offered a refund on return of the item but the buyer refused to send them back. And use ebay's messaging system to do it so the CS rep can access it and see that you did offer a refund but the buyer refused. That will count in your favor when the final decision is made.
Reply 14 of 21, by PeterLI
Propose to cancel the transaction. Have the buyer return the items. Then refund.
Perfect example why eBay s**cks.
Reply 15 of 21, by Soupdragon
The buyer just dropped the dispute, guess he was just confused and not trying to scam me. If I was unsure of something I would have contacted the seller outside the dispute system first. 🤣 Anyway thanks for the help guys. 😀
Reply 17 of 21, by RacoonRider
Soupdragon, I'm happy your issue has been resolved!
vetz, btw, how did you manage to display system info propperly? Mine is all screwed up, with text displayed outside the frames...
Reply 18 of 21, by Soupdragon
Thanks Vetz, if he hadn't seen sense those screenshots would have been a massive help. 😀
Reply 19 of 21, by vetz
What drives do you use? This is the FastVoodoo 4.6 drivers. I believe they change the look of the system info tab.
