First post, by snorg
How difficult do you think it would be to convert an ATX case to an AT case? Or just keep hunting for an AT case.
Reply 1 of 5, by bjt
There are ATX backplates for AT boards and ATX to AT converters for the PSU. However I believe the first one or two AT slots won't have an opening in an ATX case.
Reply 2 of 5, by ODwilly
From my experience if you can drill holes that line up, the 7 slot AT boards will work in an ATX case with all the card slots lining up. At least if you have a case with out the raised bumps for standard ATX layout and instead have just holes drilled into the plate that you screw the motherboard directly into. The 8 slot ones are just like bjt stated.
Reply 3 of 5, by Malik
Have a look at what I did last time with my ATX case. But that case had holes for mounting the AT motherboard.
Re: ATX-case for full-AT mobo
