First post, by ViiMaster
Hello Guys! 😀 My first post on the forum! I'm actually going in and out of the forum for quite some time but this is the first time I decided to create an account and ask a question! 😀 (I really tried to find a similar answer to it but I couldn't find something...)
I have two Creative Voodoo2 12mb cards. They both working well in SLI but I wanted to apply heatsinks on each of the CPUs to keep the temperature down and extend their lifecycle... 😀 I think that a 27mm * 27mm heatsink would do fine for the three chips on each card but when I was about to buy Adhesive Tape pads like these ones:
http://www.ebay.co.uk/itm/20PC-x-25-25mm-Squa … =item27d49753c4
It sais at the bottom of the auction:
"If you use this tape on a CPU/GPU, you will fry it.
If you need thermal protection for your CPU/GPU do NOT use this product,
use an alternative CPU-preferred thermal compound."
Do you think that the temp of the CPUs would actually fry the pads and if yes, what method should I use to attach these heatsinks...
Thank you very much!
