First post, by JoeCorrado
- Member
Kind of in unfamiliar territory and hoping for answers to some basic questions. Sorry if this has been asked and answered- I did not get results in the forum to my search query.
I would like to use a pair of Diamond Monster Voodoo 2 cards in SLI mode but the memory configuration is not equal between the cards. One is a 12MB card and the other is only 8MB- the cards appear to be completely functional so far as I can tell, they were listed (jointly I suppose) by the DxDiag tool as being adapter two- and passed the dxdiag tests ok.
If I install these cards with the 8MB card being first in line, would that mitigate the memory mis-match. The 8MB card would feed the 12MB card. The thought being that the less capable card would set the pace so to speak. Is there a problem with that, or do I absolutely need a driver set that supports "mis-matched cards" in SLI in order for it to work correctly?
Does the card mis-match that I have read about refer actually to the memory configuration, the manufacturer, or both? Maybe the answer should be plain as day, I just don't recall seeing the answer actually laid out in plain language.
I had these set up in SLI once before for a short time and Windows 98se did not complain- other issues caused me to remove them from my Windows 98 box and go with a stand alone Geforce ti-4200 but while installed- both cards were recognized and showed up in device manager as working correctly after installing the Diamond drivers- but just one showed up in the video properties applet. Is that normal?
I have had no experience with accelerator cards previous to this and it did not occur to me to question that the Diamond Applet did not specify two cards on board in SLI mode. It simply showed screens to allow adjusting various settings and applying the settings to DOS. Should it have stated information anywhere about there being two cards in SLI mode at all?
Thanks for any light you can shed- my wife says that I hate to ask for directions even when I am lost so the asking for help is a bit new for me. I hope my questions are not too lame.
-- Regards, Joe
Expect out of life, that which you put into it.
