First post, by Peter Swinkels
When taking apart an old (from ~2003) digital satellite reciever I found a 160gb Seagate IDE harddisk inside. Being curious about any data that might still on it I decided to plug it into the hot swap bay in the front of my computer. When the computer is turned on, it shuts down immediately. When I insert the hdd before turning the computer on it is simply not detected. There is a jumper set to "cable select". Removing it has not effect.
I normally have a 160gb Western Digital IDE harddisk from around 2009 plugged in the hot swap bay and it works perfectly fine. Removing and reinserting it while the computer is turned causes no problems.
My motherboard doesn't appear to have any connectors for IDE drives, so the hot swap bay is the only place where I can connect an IDE drive.
My computer:
1. Motherboard: MEDIONPC MS-7728 (CPU 1)
2. Processor type and speed: Intel Core i7 2600 @ 3.40GHz - Sandy Bridge 32nm Technology
3. Amount and type of RAM: 8,00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
4. Video board w/ RAM amount and type: SyncMaster (1600x900@60Hz) 1024MB ATI AMD Radeon HD 7450 (Elitegroup)
5. Sound board: AMD High Definition Audio Device
6. Operating system: Windows 7 Home Premium 64-bit SP1 (English)
I personally suspect that the harddisk doesn't support hot swapping or that it has failed. Any suggestions as to what I could try?
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
