ElectricMonk wrote:Any recommendation? My copy of CS5 Photoshop is flaky, and Adobe is zero help, unless I upgrade my support package.
Think GIMP or MTPaint on Mint17 or Haiku would do the job? I'm mainly after creating pixel art, sprite sheets, background layers, etc..
The closest thing I've found to Deluxe Paint in a modern program is Ultimate Paint;
http://www.ultimatepaint.com/
The freeware edition is fully functional, except that it's lacking the graphics filters of the paid version. It has some rough spots, like that holding Shift to constrain mouse movement doesn't work reliably and on rare occasions, it has crashed, so save your work often. It's very user friendly though. Left button draws, right button erases in all modes, hold on the tool icons for extra options. You can scroll the screen in zoom mode without breaking the current operation. You can hold the CTRL key to select multiple regions at once.
Unfortunately, there aren't any animation options though.
Another similar program is Saint Paint;
http://www.saintpaint.com/
It has animation options and its transparency mode works much better than in Ultimate Paint (as long as you hold down the button, the color you're applying won't mix with itself, like you're applying it to a different layer), but it also has some quirks. Like that when you cut out part of the image, it's always one pixel smaller than the selection frame. In other words, cut part of the image and then paste it back in exactly the same spot and you'll have a one-pixel gap around it.
It used to be shareware, but I don't see any option on the site to pay for it, so I guess it's free now.
