Reply 1 of 11, by Jepael
Reply 2 of 11, by Procyon
- Member
Very annoying indeed and these are just one of the many types out there.
Easiest would be to ask someone who works in a maintenance shop if he can get a fitting bithead for you.
If the screws aren't too tight maybe you can get grip with somewhat matching pliers and loosen them.
Another way is to drill a hole in the head and use a leftist tap to remove them and replace them with normal screws but that is going to be hard are the screwheads are round so the drill is going to run away.
Or if the screws are exposed enough you can saw a cut into the head and remove them with a normal screwdriver.
Reply 3 of 11, by keropi
- l33t++
Nintendo uses them since ages ago , just get the bits from eBay
Reply 4 of 11, by sliderider
- l33t++
They're security screws used in things that you're not meant to open.
Reply 5 of 11, by RacoonRider
- Oldbie
I bought a toolset on ebay China for like $10 to work with torx and many other types of heads, the screwdriver head for the one you are showing looks like a fork. A very useful thing if you deal with electronics.
Reply 6 of 11, by jwt27
- Oldbie
If you have a dremel, cut a slot in them and you can open it with a normal flathead screwdriver. Small iron saw works too if you have enough space to saw.
Reply 7 of 11, by keropi
- l33t++
wrote:[...] the screwdriver head for the one you are showing looks like a fork[...]
nope, here is the needed bit:
search ebay for "nintendo security bit"
Reply 8 of 11, by Stojke
Reply 9 of 11, by AidanExamineer
- Member
I've seen a TITAN brand bit set with a huge variety of security bits for about 12 bucks. It came with the aforementioned tuning-fork bits, but I had to special order security bits for Nintendo game carts.
Reply 10 of 11, by Stojke
Reply 11 of 11, by mr_bigmouth_502
- Oldbie
Nah, all you need is a Dremel tool. What you posted above is intended more for cutting through things like bolts and sheet metal.
