First post, by Yasashii
- Member
After almost 2 years of having the thing, I must admit the Acer Aspire One 722 is an utter piece of dudu. Aside from the fact that the performance is mediocre and the keyboard ungodly uncomfortable, the netbook has proven to be unreliable.
Around the same time last year I had to return it because the WiFi was malfunctioning and now that it's been replaced, another problem pops up: the hard drive spins down randomly and immediately spins up again, even if it's been used like a second ago. For example it has happened while loading a level in a game etc. I was just getting ready to return it again just before I noticed the warranty was only one year (no wonder, considering...)
I made absolutely sure that HDD shutdown is set to never both on AC and on battery in the power settings. To confirm 100% that the issue is not caused by any software, I also formatted the drive, and reinstalled Windows 7. I didn't install a single thing aside from the OS. Not even the drivers. The issue persists so it's not caused by software... or is it?
Funny enough, when I installed Ubuntu on it, I couldn't get the hard drive to spin down throughout the time I tested it. Either it was an amazing fluke or for some reason unknown to me, the problem is OS-related. So I'm thinking maybe there's a power-saving feature on it that's malfunctioning but it's not supported by Linux so the issue doesn't occur on it? I don't know. Also, while the spin downs do occur while several files are loaded one after another (when loading a level in a game, for example) but as far as I was able to observe, the HDD won't spin down while a single large file is being read/written.
I installed GSmartControl on Windows 7 on the netbook and ran the short self-test and the conveyance self-test. Both reported 0 errors.
There is no pattern to the spin downs. They occur completely randomly anywhere between about a minute and several minutes. Does anybody know whether the situation can be salvaged on the software level or should I just throw the bloody thing out the window and save myself some mental health?
EDIT: Check the fourth post for a solution.
