First post, by nemail
Hi
does anyone know what i have to do to be able to access network shares on a windows 8.1 computer from a windows 98se computer?
I'm able to access a share which lies on a 98SE computer from a computer with 8.1 but not the other direction.
win98se asks for a password for the IPC$ share, it seems that it is not able to ask for a user name as well...
thanks for any advices!
Reply 1 of 5, by j7n
Have you added a system user to the Win Eight box with the name equal to the login used on Win98? I have never had the system ask for a user name. It just keeps using whatever I logged on at boot time.
Reply 2 of 5, by Zup
Windows 98 uses NTLM1 passowrds, while Windows vista (and later) will refuse anything below NTLM2. There is a group policy that enables NLTM1 that works on Vista and 7, but I don't know if it still exists on Windows 8.
I'm selling some stuff!
Reply 3 of 5, by nemail
thanks, so i'd have to enable ntlm1 and create a user like i'm logged on on the win98se machine?
i'll give that a try!
Reply 4 of 5, by chinny22
I did the following so my Win7 could access my NT4 box
https://social.technet.microsoft.com/Forums/w … itpronetworking
I still need to enter login details when accessing the a Win7 share and it seems to work when the account has a password so I just created another user account on the Win7 PC and everything works fine, Im guessing 8 would be basiclly the same
Reply 5 of 5, by mockingbird
You have to disable Homegroups and then play around with the settings like change it to compatibility with 40-bit encryption and non-protected network shares. It's in the Networking section of Control Panel.
(Decommissioned:)
