First post, by maximus
Here's something that's been bothering me for a while now. Need for Speed II SE has fog in Glide mode, and it looks fantastic. Need for Speed: High Stakes also has fog in Glide and Direct3D modes, and it looks even more fantastic.
Need for Speed III: Hot Pursuit, on the other hand, doesn't seem to have any fog! I used to think this was a peculiarity of the game's Direct3D render path, but when I got my Voodoo 3 and tried the game in Glide mode, it still didn't have fog.
Did they just arbitrarily drop this feature in Need for Speed III, after implementing it so well in Need for Speed II SE? Or does it only work with the Voodoo2? (Or, is the "Enable Fog" option just really well hidden?)
PCGames9505
Reply 1 of 10, by Gemini000
The interesting thing about fog effects in the late 90s and early 2000s is they were often implemented to hide the fact that an engine couldn't render too many polygons or else the framerate would die. In real life, unless the weather itself is foggy, fog doesn't take effect until VERY far into the distance, and even then you may still be able to see things several miles away if they're big enough, such as mountains.
As game engines got better, fog effects eventually stopped being a necessity and started becoming a design decision for sake of the environment. Part of the reason is because early fog effects are not dynamic, thus if you implement them at all, sooner or later all 3D elements of the scene would need to turn into the fog colour. This meant backgrounds had to be plain colours to match the fog colour, otherwise you'd end up with bright solid white or deep solid black overtop of a colourful background, which doesn't make sense visually.
Essentially, early fog effects and background textures don't match up very nicely. :P
In terms of NFS3, I don't know if there's any hidden fog options or anything, but every screenshot I've seen of it has no fog effects, so I doubt there are any, and it was probably built that way on purpose to provide a maximal draw distance and to allow for backgrounds to mesh in with the rest of the graphics.
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 2 of 10, by Gamecollector
NFS3 with glide2x renderers (voodooa.dll, unpatched voodoo2a.dll, Banshee patch voodoo2a.dll) - fogging is ok.
NFS3 with glide3x/d3d renderers (d3da.dll, Voodoo3 patch voodoo2a.dll) - no fog.
Tested with a real Voodoo2. Maybe Voodoo3 results are different but I doubt it.
P.S. You must run the Banshee patch, not unpack it. It replaces voodoo2a.dll.
Reply 3 of 10, by Stiletto
Gamecollector wrote:
NFS3 with glide2x renderers (voodooa.dll, unpatched voodoo2a.dll, Banshee patch voodoo2a.dll) - fogging is ok. NFS3 with glide3x […]
Gamecollector FTW. Pretty sure this has been asked and answered on the forum in the past, but thanks.
do the Fandango!" - Queen
Stiletto
Reply 4 of 10, by maximus
Aha! I suspected as much! Needing to install a patch for the Voodoo3 was a big red flag.
I wonder if the Banshee patch works with the Voodoo3? I'd go test it, but my Voodoo3 is not set up at the moment.
I agree that table fog is an imperfect technique, and I've often seen it used to hide short draw distances. However, some of the Need for Speed games use it to real artistic effect (High Stakes especially), so it does seem missing in Hot Pursuit. This is especially true when weather is enabled (rain and snow falling from clear skies is not very realistic 😜).
PCGames9505
Reply 5 of 10, by Gamecollector
Well, the Voodoo3 NFS4 patch is manual. You replace 3ddata.exe/3ddata.dat. As the result - the Voodoo3 entry is added in the registry and 3dsetup.exe correctly detects/initializes a Voodoo3. The second thing - you must manually replace voodoo2a.dll.
So - install the Banshee patch then not copy Voodoo3 voodoo2a.dll... Just update 3ddata.exe/dat.
Reply 8 of 10, by PhilsComputerLab
I know. It's a hobby of mine to get Steam and GOG.com games to run on my Retro PCs 😀
YouTube, Facebook, Website
Reply 10 of 10, by maximus
swaaye wrote:
I haven't messed with NFS3 in awhile....
I don't play it much either, to be honest. I mostly use Hot Pursuit as a High Stakes substitute on systems that can't quite handle the newer game. Even though the two games are based on the same engine, there's quite a large difference in terms of system requirements.
PCGames9505
